Plusnet Profile Woes
- Plusnet Profile Woes
21-08-2013 2:12 PM
How much longer are Plusnet going to persist with the ridiculous separate profile.
Since I sorted out a decent router (Billion 7800N) my sync stops up for months at a time at above 8000 Kb/s. This is for an attenuation of around 46 dB.
However when it does disconnect (always in the early hours) it reconnects at a much lower rate and the Plusnet profile seems to instantly plummet.
I then have to wait several days (if I'm lucky) for it to return.
If other ISP's can just use BT's profile, then why can't Plusnet.
It's just one more reason to jump ship when my present contract ends.
I know that Plusnet make a big play on the local support but how often have I had to ring India about my phone line. I can't remember the last time.
If PN do eventually bring in the penalty charge for not having phone with them I shall be off like a shot.
Oldgeezer
Oldgeezer
Message 1 of 5
(711 Views)
4 REPLIES 4
Re: Plusnet Profile Woes
21-08-2013 3:34 PM
Hi oldgeezer,
Sorry to hear about this issue. I've just been looking at your account and from what I can see our speed profile has been matching that set by BT so our profiling isn't the issue here.
Line tests currently show me a sync speed of 8000kbps exactly as you've mentioned, however I can see that a 6000kbps (as opposed to the regular 7000kbps) was in place for a short while between two resyncs today, so it would appear that something may have caused the synch speed to be lower at the time of the first resync this morning. Beyond that no obvious issues are showing.
Prior to this when did you last notice the issue as that's the only instance we can see where that's happened?
Adam
Adam
Message 2 of 5
(419 Views)
21-08-2013 3:54 PM
The PN profile has reset as you say but the maximum download speed using various testers remains at around 5600 Kb/s instead of the 6800 Kb/s I can usually achieve when my IP profile is 7 or 7.1.
It's as if the profile hasn't moved.
Oldgeezer
Oldgeezer
Message 3 of 5
(419 Views)
21-08-2013 3:57 PM
Try a disconnect/reconnect of the PPP session (not a router reboot or dropping the synchronisation).
Message 4 of 5
(419 Views)
21-08-2013 4:31 PM
Thanks for that Jelv, it seems to have done the trick.
I'll remember that for next time, although I haven't had to do it before.
Oldgeezer.
Oldgeezer.
Message 5 of 5
(419 Views)
