Plusnet IP Profiles that are stuck
- Re: Plusnet IP Profiles that are stuck
21-12-2009 8:55 PM
and my profile is stuck YET AGAIN! BT says 2500, you 2000 - why are so many profiles not being updated!
22-12-2009 11:02 AM
I'm looking into the profile change stuff separately.
22-12-2009 11:03 AM
22-12-2009 4:14 PM
My Plusnet line rate seems stuck at 4000 no matter what I try to nudge it.
BT speed test/line profile is at 4500.
Router sync rate between 5611900 & 5927900.
Account name cancer
I started raising a fault through the portal but stopped when the BT test showed it was PN not catching up the rate.
After giving it a few reboots & waiting a couple of weeks it isn't moving on its own.
Can you update my PN profile rate please ?
I thought one of the worth having bits of ADSL2 was seemless rate adaption, to adjust lines up/down without help from bt/isp/customer, unfortunately I read somewhere BT have 'opted out' from this. Would that be a better long term fix ?
Ta,
Chris
chrishs at PN
22-12-2009 4:28 PM
For as long as I can remember I've been getting 350-400 kbytes per second transfer rates, which is great.
However, since last night (and a power cut) I am not lucky to get 15 kbytes per second! The router is still syncing up okay, currently:
DownStream Connection Speed 4736 kbps
UpStream Connection Speed 448 kbps
Which is roughly as I would normally expect.
I note my BT IP profile is at.... 135! What happened?! That's a sudden leap...
Investigations this end: router now moved to master socket, and plugging directly into the 'secret' socket behind it. I have replaced the microfilter and the cable between socket and router (This seemed a bit dodgy, it would cut out the phone line when touched sometimes).
I have also tried another router (DSL-504).
So I imagine it is possible there was a time when that lead was screwing the line quality, but again, didn't notice any speed problems.
To summarise: Before last night, great speeds, since then right down to 10kbytes per second.
Help! (have raised a ticket but hoping this will help push things through a bit faster)
22-12-2009 4:30 PM
I'll take a look at your profile now.
@Mewcenary
We can't alter your IP Profile, as long as you stay synced higher it will increase but can take 72 hours to do so.
22-12-2009 4:37 PM
Quote @ChrisHS
Done, you may need to disconnect/reconnect your router to see the higher speeds.
23-12-2009 10:05 AM
This went back to working perfectly last night (my BT IP profile went back to 4000). However, the profile is still 4000 this morning but my speed has dropped to about 20 kilobytes/second again.
I received a comment on my ticket to turn interleaving on - I don't want this! Especially since my last comment on the ticket was that everything was working again !
Looking at my 'Connection details' it seems my 'line speed' has been set to:
Current line speed:
250
Please can this be put back up to what it should be!
My router is still synced at 4500 odd...
23-12-2009 11:10 AM
I've upped your profile to 4000 our side, but if your BT profile drops again this will trigger another drop in our profile.
23-12-2009 11:11 AM
23-12-2009 11:14 AM
24-12-2009 10:43 AM
29-12-2009 11:17 AM
30-12-2009 1:53 AM
I know its small but I have noticed a dramatic drop in performance.
30-12-2009 10:29 AM
I've had a problem with my connect (sync speed stuck at 3069k) This resolved itself several days ago and my sync is back up around 5000k. However, my ip profile (as reported in the plusnet connection settings area) is staying at 2500. Could someone have a look at it and seeif it's stuck please? I can't think of any other reason why it would still be at 2500
Cheers
