Ping Times
- Re: Ping Times
Ping Times
05-07-2009 11:59 PM
During the day (08:00 to 18:00), on Eclipse, the slowest I ever saw pinging the BBC was 86ms - it was typically consistent between 46 to 58ms. On +net I've never got lower than 82ms - typical times are around 120ms, with occasional 230ms periods. I'm running a Netgear DG834GT with the latest firmware. I normally use OpenDNS but get the same results (a ms or two quicker) when I let +net define the DNS.
Even now (23:50) ping time is 56ms - on Eclipse this would be in the low 40s.
Any thoughts?
Re: Ping Times
06-07-2009 12:48 AM
Re: Ping Times
06-07-2009 9:42 AM
Is this still happening? I'd expect you to see ping speeds a bit lower than that even if you do have interleaving turned on.
Could you possibly show us a traceroute to the BBC to see if we can spot where the slow down is happening?
Re: Ping Times
06-07-2009 9:59 AM
Re: Ping Times
06-07-2009 10:03 AM
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\SnotGobbler>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.254.252]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.0.1
2 48 ms 49 ms 48 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 48 ms 49 ms 50 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 80 ms 205 ms 216 ms te2-3.thn-gw2.plus.net [212.159.1.58]
5 45 ms 58 ms 44 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 45 ms 44 ms 47 ms 212.58.238.133
7 45 ms 44 ms 89 ms rdirslb0.thdo.bbc.co.uk [212.58.224.136]
8 44 ms 44 ms 44 ms virtual3.rbsov.bbc.co.uk [212.58.254.252]
Trace complete.
C:\Documents and Settings\SnotGobbler>[/tt]
Re: Ping Times
06-07-2009 10:06 AM
![Undecided Undecided](/html/@B2520ED9758574DA4DA10314C4B1AB94/images/emoticons/undecided.gif)
Re: Ping Times
06-07-2009 10:08 AM
Re: Ping Times
06-07-2009 10:09 AM
Re: Ping Times
06-07-2009 10:11 AM
ICMP is lower priority traffic, so ping times can go up if the network is busy. You weren't looking at the ping times when Andy Murray was on court by any chance?
Re: Ping Times
06-07-2009 11:28 AM
No, I gave up on t'internet when Murray was playing.
Re: Ping Times
06-07-2009 11:31 AM
It seems to slow down at hop 3 or 4.
[tt]Microsoft Windows XP [Version 5.1.2600]
C:\Documents and Settings\TechnicalBaffleGab>tracert bbc.co.uk
2 51 ms 46 ms 58 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 102 ms 44 ms 62 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 44 ms 45 ms 43 ms te2-3.thn-gw2.plus.net [212.159.1.58]
5 43 ms 44 ms 47 ms rt0.thdo.bbc.co.uk [212.58.239.25]
6 44 ms 98 ms 45 ms 212.58.238.133
7 49 ms 45 ms 44 ms rdirslb0.thdo.bbc.co.uk [212.58.224.136]
8 45 ms 44 ms 45 ms virtual3.rbsov.bbc.co.uk [212.58.254.252]
Trace complete.
C:\Documents and Settings\TechnicalBaffleGab>[/tt]
Re: Ping Times
06-07-2009 11:37 AM
Another tracert done a few minutes ago.
C:\Documents and Settings\Anne Nonymus>tracert castlefarmbandb.co.uk
Tracing route to castlefarmbandb.co.uk [213.175.206.48]
1 1 ms <1 ms <1 ms 192.168.0.1
2 57 ms 83 ms 45 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 55 ms 83 ms 46 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 204 ms 229 ms 49 ms lonap.blueconnex.net [193.203.5.24]
5 50 ms 50 ms 104 ms pri.bsq3-the.as29550.net [217.112.81.90]
6 70 ms 49 ms 55 ms preston.eukhost.com [213.175.206.48]
Trace complete.
C:\Documents and Settings\Anne Nonymus>tracert www.castlefarmbandb.co.uk[/tt]
Re: Ping Times
06-07-2009 12:35 PM
Re: Ping Times
06-07-2009 12:42 PM
[tt]
Down Up
Attenuation 26 db 15db
SNR 8.1db 21db
[/tt]
As reported by the Netgear router.
Re: Ping Times
06-07-2009 12:43 PM
I've checked your line - which looks fine.
Are you running anything else which might be up/downloading data at the same time?
