Peak time packet loss on ptw-bng01
- Re: Peak time packet loss on ptw-bng01
- « Previous
- Next »
14-05-2014 5:19 PM
This is now resolved. It was a issue within the BT node which we started using a couple of months ago. It become evident when we start sending over a certain amount of traffic.
Any other packet loss issue will be a different problem. Haltdef: Still seeing it?
Kelly Dorset
Ex-Broadband Service Manager
Message 61 of 65
(701 Views)
15-05-2014 9:00 AM
Still some packet loss, nowhere near as bad and doesn't seem to be affecting throughput now. Look normal?
http://www.thinkbroadband.com/ping/share/9cef3b8b49de4967b8b35118bfbe227f.html
http://f8lure.mouselike.org/index.asp?DoAction=ViewHost&HostName=blerge.net
Message 62 of 65
(701 Views)
15-05-2014 9:04 AM
Are you running some kind of service/program on one of your network devices?
Message 63 of 65
(701 Views)
15-05-2014 9:06 AM
Quite a lot, I've tweaked my QoS settings a little, DLM has been playing with my line a lot recently - actual upload speed had dropped a bit so I've told the router about it, see if that helps.
Message 64 of 65
(701 Views)
15-05-2014 9:09 AM
Can you start a new thread so we can leave this one to die detailing what you've got?
I think we might need to return everything to a refresh start, removing your router customisations so we can see if it's actually your line, or your tweaks.
Kelly Dorset
Message 65 of 65
(701 Views)
- « Previous
- Next »
