PN IP profile check/change?
- PN IP profile check/change?
Re: PN IP profile check/change?
12-05-2015 10:27 AM
13-05-2015 7:47 AM
I've responded to those questions. Happy to meet BT at home almost anytime.
Adam
13-05-2015 8:21 AM
That RS plot is very grim. Please keep RS running and try to correlate the bad variations with use of electrical equipment. The SNRM plot should be fairly flat, until it is messing with the profile U.S. a complete waste if time.
Kevin
13-05-2015 9:49 AM
15-05-2015 2:56 PM
All was well until around 14:30 today, the line became noisy and the modem synced at just 672k - IP profile now bombed out again.
Download speedachieved during the test was - 0.34 Mbps
For your connection, the acceptable range of speeds is 0.05 Mbps-0.5 Mbps.
Additional Information:
Your DSL Connection Rate :3.14 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 0.5 Mbps
I've asked for a revisit. The last time this happened it took several visits from BT until one of them turned up with a TDR and actually watched the line. He then saw two areas on the line with 'spikes' and was able to go and find/fix them. These visits will be a waste of time until this happens again IMO
Adam
15-05-2015 3:02 PM
As you can see, perfectly behaved for hours before.
Adam
ps the BT engineer did say that the CAB 4 (weobley) I'm attached to has fibre offerings, can PN offer a fibre service on my line? If so, I'd jump at it.
15-05-2015 4:41 PM
With regards to Fibre it's enabled at your cabinet however it looks like your too far away from the cabinet to receive a speed above 1mbps.
15-05-2015 7:07 PM
Can you please review your setting for RS (see link below) - these should lead to us being able to see the synch speed on the same graph as the SNRM.
Can you hear noise on the phone line / have you recently done a quite line test? Dial 17070 option 2 using a corded phone in the master socket.
Kevin
16-05-2015 9:38 AM
See charts from this morning, when I checked the line it was very noisy. Unfortunately, the line is perfect when the BT engineer calls
16-05-2015 12:51 PM
Quote from: gingerbloke Engineer called, line tested fine. He replaced the master socket with a new Mk3
Did he replace the whole master socket or just the front Mk3 plate?
Sometimes a temporary cure can be effected by ringing your own line - the ringing current cleans up a bad joint temporarily - assuming that's the cause and not an intermittent break - is the line an overhead one? (Use 17070 option #1 to ring your own line).
16-05-2015 4:32 PM
I'll try the call 'clear' but at the moment the line is running perfectly.
16-05-2015 7:51 PM
Intermitant noisy lines are around the hardest to fix properly. The SNRM is far higher than it should be, but without clear knowledge of the target, it is not possible to clearly state (guess) if this is down to an elevated target or the line previously synch'd in the presence of noise high is now not present.
@CRT,
Can you comment please and recommend the next step to resolve this issue please?
Kevin
17-05-2015 12:04 PM
I did record one of these calls, but the format cannot be uploaded here.
A few minutes later (7:10am) the line went noisy of it's own accord and the modem resynced lower.
Just an aside, why does the IP profile (effectively a 'least worst rate') take so long to reflect sync rate improvements? Having to wait 72 hours with unusable broadband just because it synced at 672k a few days ago is maddening. Surely in the 21st century it should be updating itself daily or hourly?
Adam
17-05-2015 12:12 PM
Assuming you have the TG582n, log in to your modem/router and go to the Internet Box as shown here and click Disconnect. This drops the PPP session to the ISP. Wait about 30 seconds and then Click Connect.
Edit: As you already have a Phone (I assume) fault ticket open on this, you could zip your recording and attach it to the ticket.
17-05-2015 3:09 PM
It running around 55Kbytes/s, so something else is throttling me at the moment as the BT IP profile is showing as 2Mbps.
I will add the noise recording to the ticket for phone fault, thanks. (update, tried but cannot add this type of file (zip))
Adam
Download speed achieved during the test was - 0.45 Mbps
For your connection, the acceptable range of speeds is 0.4 Mbps-2 Mbps.
Your DSL Connection Rate :4.1 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
IP Profile for your line is - 2 Mbps
