Not really a new topic - Peak Time slowdown still happening.
- Not really a new topic - Peak Time slowdown still ...
Re: Not really a new topic - Peak Time slowdown still happening.
18-05-2013 12:48 AM
which is the best I've had for ages, although I had previously been getting over 14Mb downstream. I'm not sure if all the work (tree cutting was mentioned) has been done, and I can't tell from my new BT Hub 4 if interleaving has been switched off - the lowering of pings from mid-40s to mid-20s suggests it may have been.
ETA: Just so it's clear the above speed test isn't a flash in the pan, I've just run a TBB speedtest - my graph there goes steadily downhill, but this is right up there...
And a proper ping:
[tt]
C:\Users\Brian>ping -n 10 ntp.plus.net
Pinging ntp.plus.net [212.159.6.9] with 32 bytes of data:
Reply from 212.159.6.9: bytes=32 time=31ms TTL=250
Reply from 212.159.6.9: bytes=32 time=39ms TTL=250
Reply from 212.159.6.9: bytes=32 time=30ms TTL=250
Ping statistics for 212.159.6.9:
Packets: Sent = 10, Received = 10, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 30ms, Maximum = 39ms, Average = 31ms[/tt]
18-05-2013 12:46 PM
ADSL Line Status
Connection Information
Line state: Connected
Connection time: 0 days, 00:08:24
Downstream: 16.49 Mbps
Upstream: 1.086 Mbps
1. Best Effort Test: -provides background information.
Download Speed
14.01 Mbps
0 Mbps 21 Mbps
Max Achievable Speed
Download speed achieved during the test was - 14.01 Mbps
For your connection, the acceptable range of speeds is 4 Mbps-21 Mbps.
IP Profile for your line is - 14.9 Mbps
Upload Speed
0.94 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.94Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.83 Mbps
[tt]C:\Users\Brian>ping -n 10 ntp.plus.net
Reply from 212.159.6.9: bytes=32 time=35ms TTL=250
Reply from 212.159.6.9: bytes=32 time=36ms TTL=250
Minimum = 35ms, Maximum = 36ms, Average = 35ms[/tt]
Looks good so far - proof of the pudding will be later this evening...
18-05-2013 4:36 PM
18-05-2013 7:20 PM
18-05-2013 7:27 PM
18-05-2013 7:44 PM
(Switched to Maidenhead)
Download Speed
6.73 Mbps
0 Mbps 21 Mbps
Download speed achieved during the test was - 6.73 Mbps
Upload Speed
0.92 Mbps
0 Mbps 0.83 Mbps
Upload speed achieved during the test was - 0.92Mbps
Reply from 212.159.6.9: bytes=32 time=40ms TTL=250
Reply from 212.159.6.9: bytes=32 time=42ms TTL=250
Reply from 212.159.6.9: bytes=32 time=38ms TTL=250
Request timed out.
Reply from 212.159.6.9: bytes=32 time=37ms TTL=250
Reply from 212.159.6.9: bytes=32 time=41ms TTL=250
Packets: Sent = 10, Received = 9, Lost = 1 (10% loss),
Minimum = 37ms, Maximum = 42ms, Average = 39ms[/tt]
(Edited to correct speedtest.net server name in line 1. D'oh!)
18-05-2013 8:05 PM
Sorry if it's been asked before, I couldn't see it, any of your neighbours or anyone else you know on the same exchange on a BTw product seeing similar issues?
18-05-2013 8:17 PM
We'll see...
18-05-2013 10:25 PM
20-05-2013 5:16 PM
2:34pm, Saturday 18 May 2013
Internal
18/05/2013 12:30:35 CRM User Attention - Escalation update: Suppliers informed that that the controls have kicked the engineer activity for pole work and the next review date is on 21/05 after 1600 hours. We will post you once we have an update.
2:36pm, Saturday 18 May 2013
Dear Mr (Removed),
Putting on hold
The next action on your Help Assistant Question is due on Tuesday 21st May at 7:00am. This Question will remain open with the BOT - DSL Logged Faults ADSL2 - Speed until this time.
No mention of the engineer visit (not appointed) I had on Saturday, where the engineer's JDSU test showed what would have been a completely non-working line, when he swapped pairs and the line test is now fine but no noticeable change to the ADSL performance in the evenings.
I also have a BT IP profile of 14.93 Mbps but my Current Line Speed is 21.5 Mb. I've certainly never synched high enough for the latter figure to be correct!
Also no word of the escalation with the traffic management team mentioned further up-thread by Chris Purvey (reply no 51).
21-05-2013 9:52 AM
We'll keep you updated.
21-05-2013 3:56 PM
[tt]IP Profile for your line is - 14.9 Mbps[/tt]
[tt]Current line speed: 21.5 Mb[/tt]
As I said, I've never synched high enough for the latter figure to be anywhere near accurate.
21-05-2013 4:00 PM
We received an update regarding the escalation and they are now advising that any issues should be resolved although I've asked our faults team to chase this up to confirm.
Let me know what you're connection is like tonight.
22-05-2013 1:41 AM
22-05-2013 11:45 AM
