No Internet, orange lights on hub
FIXED- Subscribe to RSS Feed
- Re: No Internet, orange lights on hub
01-04-2020 11:53 AM
No tech support via phone, so what to do next? Any other people having problems or reported issues?
Unhappy as this means unable to work from home - which has significant financial knock ons
Fixed! Go to the fix.
01-04-2020 12:09 PM
01-04-2020 12:10 PM
where are you?
My mum in Cheltenham has also reported the same problem about 30mins ago
cheers
01-04-2020 12:33 PM
Please plug your router into the test socket with no other devices connected. Please also check and confirm that there is no damage to any of your equipment or wiring. Please leave your router in this set up for a minimum of 3 days. Please also try an alternative router and/or microfilter if you have them.
The test socket is in the master socket so you need to take the cover off the master socket, then plug in the router. He said if it hasn't connected in 2 hours, to call them back. If it does, leave it there for a few days to monitor it.
Hope this helps. Mine is now plugged in and we will see if it connects.
01-04-2020 12:49 PM - edited 01-04-2020 12:54 PM
Plugged into test socket and changed filter. Given another plusnet customer in Cheltenham has the same issue, i don't think expecting people to wait 3 days is an acceptable response either...
01-04-2020 1:15 PM
01-04-2020 1:37 PM
Hi, update, the router is back to blue light - can you check yours too?
I had changed the filter and plugged into the test socket but to no avail, so could try restarting the router if still orange for you?
I kept the router hub window open in my browser, so I could see it trying to connect every x seconds (30?), and it eventually succeeded.
Fingers crossed it's working for others in Cheltenham now too.
01-04-2020 4:38 PM
