Netgear DG834 with dropped connections
- Netgear DG834 with dropped connections
02-09-2009 6:50 PM
I'm not saying our routers are at fault but I did a search on the internet for BT IP profile problems and the DG834 family came up pretty regularly. I'm wondering if there's something about it that it sometimes syncs badly and then causes low IP profiles or something. It could just be that it's a popular model and therefore there are more problems with it but seems to be an odd coincidence.
Re: Netgear DG834 with dropped connections
02-09-2009 6:57 PM
Is this what you are seeing
02-09-2009 7:20 PM
02-09-2009 8:36 PM
As a first step can you post your router stats - noise margin, attenuation and speeds.
Next can you download and install Routerstats as this will allow much better fault diagnosis http://www.vwlowen.co.uk/internet/files.htm
02-09-2009 8:45 PM
I think I may have posted this in the wrong place. I wasn't really trying to diagnose my problem, since that is elsewhere. I was more trying to find out whether there are other Netgear DG834 users with problems since I seem to see a lot of IP profile issues concerning that particular family of routers.
02-09-2009 8:49 PM
http://community.plus.net/forum/index.php/topic,79073.0.html <-- DG834G
http://community.plus.net/forum/index.php/topic,77830.0.html <-- DG834GT (my thread)
and it turns out right now that those are the top 3 threads in this forum other than this one because of my previous post.
02-09-2009 9:03 PM
I have a DG834G with the Broadcom chipset and it absolutely rock solid at 4000kbps with a noise margin varying from 6dB to 3.7dB over 24 hours
02-09-2009 9:07 PM
03-09-2009 2:52 AM
some might say am bias towards the v4 broadcom but if it works dont knock it
03-09-2009 8:23 AM
03-09-2009 8:46 AM
Oh and sync speed 6880 kbps, attenuation 6.x dB. I am not close to the exchange so everything is really good for me (at present).
03-09-2009 8:48 AM
The more people there are that use them, the more people you'll find with a fault.
03-09-2009 8:53 AM
Quote from: jayed It could just be that it's a popular model and therefore there are more problems with it but seems to be an odd coincidence.
^^^ Yeah, what he said
Is DG834PN a Plusnet messed about with one? I've got an ex-sky one and had been using that one as my main. Not sure if that is different hardware-wise or not but I'm not using my original Netgear branded one and still having issues (although not right this minute touch wood)
03-09-2009 9:15 AM
We also don't and never have, supplied Netgear Routers.
03-09-2009 10:11 AM
