Need more speed!
- Re: Need more speed!
Need more speed!
11-07-2009 11:28 PM
I currently have the Premier Option 1 package (which I'm quite happy with) but it's still at the ole speed of 2Mbps.
I was wondering if it's possible to keep the same package but move to the higher 'upto 8Mbps' speed?
According to BT's line tester, I should be able to get upto 5.5Mbps which seems like a worthwhile increase.
Cheers!
12-07-2009 8:04 AM
12-07-2009 9:27 AM
B.
12-07-2009 10:46 AM
12-07-2009 5:14 PM
Do I still need to raise a ticket or will you just remember it?
Cheers!
13-07-2009 12:45 PM
You're actually already on Max.
Can you try rebooting your router and see if you get faster speeds?
13-07-2009 12:52 PM
Sync speed, attenuation, noise margin
13-07-2009 7:22 PM
I swear on all my previous Speedtest.net results I've been getting 1.8 - 1.9Mb/s.
Now this evening I try it (without rebooting the router) and get 4.54Mb/s, which is great.
I'll keep an eye on it for a while.
Thanks.
13-07-2009 7:38 PM
I had to do some manual changes to your account first to get your speeds up to where they should have been.
13-07-2009 9:37 PM
In that case, thanks very much for whatever you did.
Cheers!
