Moving home - Unlimited Fibre Extra to Unlimited broadband 10 months remaining on contract Options?
bex552
Current house I have unlimited fibre extra with 10 months left on my contract, will be moving in the next month to new house which postcode checker is telling me I can only get Unlimited broadband, the speeds are way to slow due to the need of working from home. What are my options? Currently pay £25.13 per month. Any help much appreciated, thank you
23 REPLIES 23
Legend
Fixes: 257
Re: Moving home - Unlimited Fibre Extra to Unlimited broadband 10 months remaining on contract Optio
@bex552 The postcode check is not that reliable. Do you know the current phone number of the property you will be moving to?
bex552
I do know the number yes, and when i put that in the checker too its still coming up t he same, broadband only
Legend
Fixes: 257
OK, @bex552 , can you post a screenshot of that page - I wonder if you are moving to a Full Fibre priority exchange area?
Fixes: 420
@bex552
Have you checked to see if WBC FTTP is available?
If not it’ll probably be the choice between taking the slower service or paying the cancellation charge.
bex552
Legend
Fixes: 257
@bex552 Not quite what I was expecting - can you post the result of: BT Broadband , obscuring the phone number?
bex552
Apologies, I have edited
Legend
Fixes: 257
Yuk, @bex552 - That is definitely not good, but that is all you are going to get. Out of curiosity, which exchange is it on?
bex552
Legend
Fixes: 257
I don't know the area, but looking at that, it must be VERY rural.
Would you consider Virgin - If it WAS available?
bex552
Thats the annoying thing it really isnt! It is classed as a village but it is one of uks biggest! Where i currently live has a similar population which is why i dint think i would have a problem! Its only 4 miles away from cheltenham!
bex552
Yes i would consider virgin, the only problem with that is they are not sure the house can get virgin either, they have to send an engineer out to check!
Legend
Fixes: 257
Unfortunately looks like you are stuck, then. 😥
Legend
Fixes: 257
If others in the area (local streets) can, then the chances are you may be lucky - all depends if your street has been cabled. Virgin should know this without having to send out an engineer.
