Moan moan adsl2+ is slow
- Moan moan adsl2+ is slow
Re: Moan moan adsl2+ is slow
18-06-2009 11:38 AM
Connection Speed 3070 kbps 802 kbps
Line Attenuation 54.5 db 31.3 db
Noise Margin 6.2 db 10.0 db
So can anynoe explain why ive gone from 5mb/s on adsl to 3mb/s on adsl2+, there has to be an error somewhere surely?
18-06-2009 11:51 AM
Like you, I'm a little surprised that your speeds aren't higher.
18-06-2009 11:54 AM
18-06-2009 11:59 AM
Quote from: Jameseh Does your router report on connection errors at all?
only just rebooted but this is all i can find:
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 8825 14056 0 1071 9290 00:26:54
LAN 10M/100M 15358 9842 0 9512 1239 00:27:47
WLAN 11M/54M/108M 455 314 0 73 24 00:27:43
Quote from: Oldjim
Any idea as what your reported attenuation was on vanilla ADSL
got pre adsl2+ stats on the other page
18-06-2009 1:10 PM
18-06-2009 2:08 PM
Could a change from fastpath to Interleaved explain some of the speed drop?
18-06-2009 2:40 PM
18-06-2009 3:08 PM
Quote from: jelv Could a change from fastpath to Interleaved explain some of the speed drop?
18-06-2009 4:21 PM
Quote from: jelv From the posts you've made of stats it looks like you have a Netgear DG834x router. If that is the case can you download and run RouterStats. On the Telnet Router tab you will find error reporting. We'd also be interested in Bits/Tone which it also shows.
ok have the app running, guess i sholds keep in running all night? i think i have all the graph boxs ticked in the telnet area, all new to me atm.
18-06-2009 4:24 PM
its the 15 min intervals of error reporting that will tell the most as you if one 15min interval records very few errors and you end up with a massvive improvment of thought speed in that same period you know youve found the offender
18-06-2009 4:27 PM
18-06-2009 4:47 PM
Noise Margin: 6.5 dB
Connection Rate: 3067 Kbps
Line Attenuation: 54.5 dB
Power: 0.0 dBm
Max Rate: 8180 Kbps
SF: 16719
SF Errors: 0
Reed Solomon: 14846770
RS Corrected: 1574
RS Un-Corrected: 0
HEC: 0
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 160
upstream tx:
Noise Margin: 9.3 dB
Connection Rate: 805 Kbps
Line Attenuation: 31.3 dB
Power: 12.9 dBm
Max Rate: 836 Kbps
SF: 15733
SF Errors: 32
Reed Solomon: 113137
RS Corrected: 55
RS Un-Corrected: 0
HEC: 9
Errored Seconds: 0
Severe ES: 0
Interleave Depth: 2
totals
Total Up Times (From SF counts):
WAN: 0 day, 00:05:05
LAN: 0 day, 00:49:46
CRC: 0
LOS: 0
LOF: 0
ES : 0
Bytes Transferred (ppp0):
Tx: 56232 (54.9 KiB)
Rx: 185041 (180.7 KiB)
IP address: 87.114.71.215
18-06-2009 4:53 PM
18-06-2009 5:01 PM
19-06-2009 1:25 PM
