Lower Sync / Broadband speed , stuck profile?
- Lower Sync / Broadband speed , stuck profile?
25-06-2009 10:04 AM
I just want to understand few things about sync and speed.
I havent use my Internet conection hardly for 2-3 weeks, so i havent check sync speed and bandwith but when i finally did seems that my sync speed is lower than it used to be
It used to be 7150 now it shows 6500 I asked Plus.net why is that but got answer that there is nothing wrong with my connection. 6500 sync means that my speed is lower than when i was on 7150
so is that BT putting more people on exchange and it all goes down or what?
My router shows:
DownStream Connection Speed 8128 kbps
UpStream Connection Speed 448 kbps
And I ALWAYS used to have speed 6.6 - 6.8 without problems
I tested that with mybroadbandspeed.com
Date Download Speed Upload Speed
Today 20:55 4807 kbps (601kB/s) 383 kbps (47.9kB/s) and so on .... If Im lucky i can get 6 late night
Then i tested speed with BT speedtester:
Test1 comprises of Best Effort Test: -provides background information.
Your DSL connection rate: 8128 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
IP profile for your line is - 7150 kbps
Actual IP throughput achieved during the test was - 119 kbps <---
Throughput is 119 How accurate are BT speedtester results?
BT speed tester IP profile shows 7150 but plus net website shows 6500, i raised ticket and Plus.net tested my line with results below
Quote Upstream Link Info
Loop Loss Loop Loss Add Text SNR Margin Errored Seconds HecErrors Cell Count Speed
18 15 6 0 1982036929 448
Downstream Link Info
Loop Loss Loop Loss Add Text SNR Margin ErroredSeconds HecErrors CellCount Speed
33 7 0 0 -1601666075 8128
DSL Max Data
BIP Interface Data
Current line rate Line rate change timestamp Maximum Stable Rate Recalcuated ProfileTimestamp Maximum Stable Rate
6500 2009-05-30T21:38:45 N 2008-02-05T00:00:00 8128
Fault Threshold Rate Interleaving Flag ServiceOption ServiceOption Status ServiceOption Update Timestamp
6502 A 1 THIS LINE IS STABLE AND WITHIN ERROR/RETRAIN LIMITS FOR THE CHOSEN SERVICE OPTION (ILQ=A)
I have here previous test for comaprison that shows 7150 on my line
Quote DSL Max Data
BIP Interface Data
7150 2008-11-30T00:15:00 N 2008-02-05T00:00:00 8128
6502 A 1 THIS LINE IS STABLE AND WITHIN ERROR/RETRAIN LIMITS FOR THE CHOSEN SERVICE OPTION (ILQ=A) 2008-03-30T12:03:01
Rebooted router couple of time in different times to update profile with no luck, tried different microfilters, all is connected to master socket.
Does any one have idea why sync speed -> download speed goes down? It is stable no drop in connection its just slower than usual.
Thanks for any input
Goomy
Re: Lower Sync / Broadband speed , stuck profile?
25-06-2009 10:13 AM
I've just changed your profile from 6500 to 7150Kbps.
Quote DownStream Connection Speed 8128 kbps
That's your sync speed, which looks fine.
Do you want to try rebooting your router and running another speedtest?
25-06-2009 10:16 AM
That was quick
I cant test it right now , disabled access to router via http so i can test i later tonight. I will let you know how it goes.
Thanks!
I checked it just after your post and it was 7150.
Now i looked on the Plus.net website and it shows
Estimated line speed:
Not recorded (service activated before we introduced estimates).
Current line speed:
6500
So back to 6500 ..... 😕
25-06-2009 7:02 PM
now
thinkbroadband :
Date 25/06/09 18:59:14
Speed Down 3127.17 Kbps ( 3.1 Mbps )
Speed Up 377.95 Kbps ( 0.4 Mbps )
Port 8095
Server speedtest1.thinkbroadband.com
My broadband speed:
Today 18:55 3623 kbps (453kB/s) 311 kbps (38.9kB/s) Share
Yesterday 22:21 5532 kbps (742kB/s) 380 kbps (47.5kB/s) Share
Its even worst .... I tested that on win 7 , Kubuntu , and Debian with same results ... any ideas?
I am really close to request MAC and switch to BE now...
26-06-2009 9:52 AM
Yesterday evening was really busy because of the Michael Jackson news, which could have impacted the result you were given.
26-06-2009 11:12 AM
Off peak test last night got to 5.5 - 5.6 , 3 AM test got to 5.8. I looked in mybroadbandspeed.com history and i can see that test on 20-24 May speed was 6.5 and higher as it was in last months.
And why this sync speed went back to 6500 ? Ive seen it after you changed , havent got chance to test line at home from work before i was able to it was back to 6500.
I havent use my bandwitch as much as i used to in last 2 weeks but i dont think that lower usage can lower sync speed. Just trying to understand this change in sync.
Thanks for your input, really appreciate it.
26-06-2009 11:17 AM
It does sound a bit like network/exchange congestion, especially last night.
To put it into context, we saw around 1.1Gbps iPlayer traffic last night when the news about Michael Jackson was doing the initial rounds. thats the second highest we've ever seen, almost eclipsing Shu as the Stig on Top Gear.
26-06-2009 11:29 AM
Quote 5.5-5.8Mbps sounds about right for a 6500Kbps profile.
Yes it is right for 6500 profile, but mine used to be 7150 and i cant really understand why on the beggining of this month (based on mybroadband speed previous tests) it went down.
I thought that it is congestion in first place, but when situation was "stable" wtih this sync even after few reboots I raised ticked with tech support.
They say no issues,and i understand that they get same results. on the line, I havent changed any hardware.
Quote To put it into context, we saw around 1.1Gbps iPlayer traffic last night when the news about Michael Jackson was doing the initial rounds.
thats why i did test around 3AM to check and it was faster but not as fast as it used to be. My point is that i dont really want to be in position "you should be happy that it works at all" , or "I would like to have that 5.8 you have",
When something was working on 6.5 and higher i like it that way. I'm trying to understand from where this change came from and why sync is lower than usual, is that because network balancing ? BT puts more people on my exchange... really running out of ideas.
Can you tell me what happened when you changed sync to 7150 it went back to 6500, is it actual setting on exchange and that's why it went back to 6500 ? Thanks
26-06-2009 11:32 AM
If you're syncing at 8128Kbps currently and hold onto it, your profile should be amended by the start of next week.
Understand it's not ideal but unfortunately it is completely outside of our control.
26-06-2009 11:58 AM
Thanks.
Goomy
30-06-2009 9:58 AM
I've done checks again over last few days and have constant speed 6000 and ip profile 6500. I thought that my sync will increase to previous level (7150)
I did checks in peak and off peak hours and it seems that my sync is not going back to previous value.
I used mybroadband speed , speedtest.net , thinkbroadband.com and bt speedtester - on bt speed tester my sync rate was jumping from 2000 to 5500 (how accurate sync values on bt speedtester are) ?
Plus.net website :
Current line speed:
6500
Quote [-=Internal=-]
IP profile is still 6500 but WP profile has been increased to 7150. I'm going to correct this mismatch, due to the fact that it can cause a small amount of packet loss. Otherwise the line is fine, and it's simply a case of waiting for DLM to increase the IP profile to fit with the sync rate.
33 8 0 0 -1599355693 8128
BIP Interface Data
And i was waiting for DLM to increase the IP profile, how long this takes? It is already over 72 hrs and no luck.
I had but Plus.net support asked me to reboot router... anyway , my router is on 24/7 so i left it running and downloaded some big files, still no luck.
Quote Our checks aren't showing any issues with the line itself, other than the fact that your IP profile hasn't lifted back to 7150 yet, though this will be due to the fact that you've not had a stable 72 hour connection since this dropped slightly to the current 6500.
thats roll back of the change that you Jameseh putted for me in sync settings.
Quote You will notice that the speed shown on the portal has dropped back to 6500. This has been done due to the fact that if this is set higher than your actual BT IP profile you may experience issues with the connection, due to our system trying to send you data faster than the exchange has set your line to handle.
my speed test from last days of May shows 6.6 and over speeds , as I mentioned before now late night 6,0 is max i can get. Connection is stable no problems there. Just lost 0.6 + Mb/s , so what happen in next few months ? another 0.5 ? and another and another till it gets to some silly number. .. Any ideas guys ?
thanks
Goomy
30-06-2009 10:12 AM
Your profile is showing as 6500Kbps on both our system and that of BT. The profile at our end was dropped to 6500Kbps in line with BT. If we put the profile higher than the BT one is can cause your connection to suffer from packet loss.
If your connection remains as it is, without any drop in connectivity, you will receive a profile of 7150Kbps. The only thing you can do now, is to wait.
10-07-2009 1:08 PM
I waited as suggested, and performed few tests in different hours, peak and off peak.
heres some info I collected:
25 June
Quote Your DSL connection rate: 8128 kbps(DOWN-STREAM), 448 kbps(UP-STREAM)
26 june - 22:20
Quote Test1 comprises of Best Effort Test: -provides background information.
Actual IP throughput achieved during the test was - 5634 kbps
my broadbandspeed
Today 22:23 5992 kbps (749kB/s) 382 kbps (47.8kB/s) Share
Speed Test Results
Date 26/06/09 22:26:26
Speed Down 3712.18 Kbps ( 3.6 Mbps )
Speed Up 360.03 Kbps ( 0.4 Mbps )
Port 8095
Link: http://www.thinkbroadband.com/speedtest/results/id/12460515233598184575.html
27 june 9:30
28 June 10:40
1 July 2009
04 july 2009
6 july 2009 18:50
Actual IP throughput achieved during the test was - 131 kbps
Today 20:00 5994 kbps (749kB/s) 382 kbps (47.8kB/s) Share
July 9
as you see all stats are almost the same.
My router was on solid 334 hrs and profile havent update to 7150 still on 6500
Connection Status
Connection Time 334:27:02
Connecting to Server Connected
Negotiation Success
Authentication Success
Modem Status Connected
So i rebooted router and bt speedtest from today below.
10 June
Actual IP throughput achieved during the test was - 590 kbps
Quote Date Download Speed Upload Speed
Thursday 22:07 5940 kbps (743kB/s) 383 kbps (47.9kB/s) Share
Monday 20:00 5994 kbps (749kB/s) 382 kbps (47.8kB/s) Share
Jul 4, 21:54 5985 kbps (748kB/s) 382 kbps (47.8kB/s) Share
Jul 1, 20:11 5978 kbps (747kB/s) 383 kbps (47.9kB/s) Share
Jun 28, 10:41 5994 kbps (749kB/s) 381 kbps (47.6kB/s) Share
Jun 27, 09:31 5986 kbps (748kB/s) 383 kbps (47.9kB/s) Share
Jun 27, 09:30 5983 kbps (748kB/s) 383 kbps (47.9kB/s) Share
Jun 25, 19:11 5067 kbps (633kB/s) 376 kbps (47kB/s) Share
Jun 25, 18:55 3623 kbps (453kB/s) 311 kbps (38.9kB/s) Share
Jun 24, 22:21 5932 kbps (742kB/s) 380 kbps (47.5kB/s) Share
Jun 23, 21:41 6033 kbps (754kB/s) 377 kbps (47.1kB/s) Share
Jun 23, 19:38 4381 kbps (548kB/s) 382 kbps (47.8kB/s) Share
Jun 22, 22:08 5493 kbps (687kB/s) 373 kbps (46.6kB/s) Share
Jun 21, 20:55 4807 kbps (601kB/s) 383 kbps (47.9kB/s) Share
Jun 21, 20:03 6006 kbps (751kB/s) 383 kbps (47.9kB/s) Share
On all bt speedtester results profile for my line is - 7150 kbps , Plus.net website indicate 6500 speeds, and I've been told that Jameseh change to 7215 had to be reversed to 6500 because it would result in packages lost. If speedtester shows profile 7150 is it accurate ? what bugs me its that it was fine to the end of May.
Reading articles on plus.net website "we just installed 150mbs more bandwith bla bla" iam thinking, ok so extra speed, great but wheres my speed gone?
Quote The only thing you can do now, is to wait.
how long ? Im really tempted to switch to different provider...
Goomy
10-07-2009 3:02 PM
I've moved your profile back to 7150Kbps.
Can you reboot and retest and let us know if you see an improvement or a decrease in speed.
