Lost connection since this morning
- Re: Lost connection since this morning
21-07-2009 10:37 AM
Quote from: Richchad Just had this reply for my ticket.....'Please be advised, we offer a Thompson 4 port wireless router not a Speed touch router'....isn't that the same, a Thomson Speedtouch 585v7 router?
Another mission for the GM Maestro!
23-07-2009 3:13 PM
A question, on my Voyager 2091 I was able to enter the MAC key of my laptop to ensure that was the only wireless device connected, I can't find any option on the Thomson router for this, I have selected WPA2 with the Encryption key, is there anything else to restrict connections to just my laptop and mobile?
23-07-2009 3:19 PM
23-07-2009 3:23 PM
Quote from: pierre_pierre the wpa key is preinstalled, or it was in Jan when I got mine, the key is printed on the bottom of the router
Thanks for the reply pierre, I got the WPA key okay, all up and running but was looking for an option to enter the MAC key of my laptop as I did with my old router to limit wireless connection to just the laptop?
23-07-2009 3:31 PM
23-07-2009 3:53 PM
where can I download a v6 manual, can't see one on Thomson website?
23-07-2009 4:01 PM
It refers to an Access Control List
I have uploaded it to here if it will help http://www.holtlane.plus.com/files/ST585_UserGuide.pdf
23-07-2009 4:18 PM
Can't find anywhere in the V7 manual about registering clients or lists etc.
I must be missing something here.................
23-07-2009 4:42 PM
23-07-2009 5:12 PM
5.2 is about assigning a service (HTTP, FTP,...) to a computer and not page 39 that is about Dynamic DNS.?
http://www.thomson.net/GlobalEnglish/customer-service/SpeedTouchDocuments/xDSLGA-Wireless_SetupUserG...
23-07-2009 5:21 PM
23-07-2009 5:46 PM
Their manuals are a bit confusing, both say for the same router?
Maybe you should have a link to the correct one on the website or something in the leaflet you enclose with the router, or maybe you have and I just didn't look.
Anyway thanks for your help, we got there in the end.
23-07-2009 6:07 PM
23-07-2009 6:23 PM
Just needed the right manual to see how it was done, had to select that option, then do a search for wireless devices with the correct SSID otherwise it wouldn't connect.
Thanks anyway.
23-07-2009 6:49 PM
Does anyone know how I can improve the signal, or change my Dell laptop adapter settings to receive a better signal, if I can't I will be very disappointed with the new router, thought if anything this would be an improvement not worse.
Hope someone can help..............
