Little peak time latency humps
jimbof
Re: Little peak time latency humps
Looking at a few forums but nothing much of significance.  Did a couple of speed tests a while ago.
The pattern I see is that regardless of browsing, sometimes I see virtually no hump (mostly Saturday nights it seems) and then others I see the small humps as per the second of my graphs.  I do more or less the same browsing most evenings.
30FTTC06
Fixes: 4
All i can offer for the 11th around 10 ish is dns failure. I use opendns on all but a few of my devices so i wouldn't of noticed.
Amos91
Quote from: Amos91
At work currently but I believe from a trace route home I am on PCL-AG02.
1  205ms  RS-Gateway.local [78.129.174.1]
2  0ms    87.117.211.45
3  1ms    593.core1.thn.as20860.net [62.233.127.173]
4  1ms    202.core1.hex.as20860.net [62.233.127.1]
5  1ms    linx-gw2.plus.net [195.66.236.164]
6  1ms    ae1.pcl-cr02.plus.net [195.166.129.3]
7  1ms    vlan128.pih-gw3.plus.net [212.159.0.199]
8  2ms    link-b-central10.pcl-ag02.plus.net [212.159.2.167]
9  10ms   My router
Will update tomorrow morning with an updated graph. I've noticed that there has been the odd ping spike at peak times to both google.co.uk and bbc.co.uk (30ms-100ms). Pretty disappointing start to Plusnet coming from the non-traffic shaped Be*.
Always wondered if you are so far below capacity, would no traffic management actually make it go over? Funny how your testing it as the cause.
My current graph below:
Not been in to use the Internet since now. Flat so far...
Kelly
Fixes: 9
Yeah, I was thinking your graph looked better.  Run some ping tests to see if your latency stays consistent.
Kelly Dorset
Ex-Broadband Service Manager
Amos91
BBC over 100 packets:
Ping statistics for 212.58.251.195:
    Packets: Sent = 100, Received = 99, Lost = 1 (1% loss),
Approximate round trip times in milli-seconds:
    Minimum = 10ms, Maximum = 13ms, Average = 10ms
Google over 100 packets:
Ping statistics for 173.194.34.95:
    Packets: Sent = 100, Received = 100, Lost = 0 (0% loss),
    Minimum = 10ms, Maximum = 49ms, Average = 10ms
Blim
Your session timed out while posting. Please try to re-submit your message.
I hope this is still of some help. The bandwidth in use is about the amount you would see from a game but much less if you was the host in mw2-3 or bo2, console or PC.
Kelly
Fixes: 9
What gateway are you on blim?
Kelly Dorset
Blim
Which gateway
You are currently connected to gateway pcl-ag05.
This is located in City Lifeline House.
Sorry I thought I had everything covered.
Kelly
Fixes: 9
Ok, so you are old config.
Kelly Dorset
@Blim -
Quote from: dave
Change made on PCL-AG01 and PCL-AG02. If you can help and get on to one of those gateways would be really appreciated. Even if you aren't in to do any testing, if your line is on one of them and you have a Thinkbroadband test set up that would be useful for us to see too.
Blim
Ok no problem.
I was told to use a pcl gateway because they have the upgraded traffic management system and would prioritize my gaming traffic correctly. Can you confirm this is true and if not witch gateway is best for gaming? Thanks.
Will change to PCL-AG01 or PCL-AG02 as soon as I can regardless.
Kelly
Fixes: 9
Most of the gateways are now converted across to the new DPI kit.
Kelly Dorset
Blim
Done. 22:30'ish
Just so you don't miss this, the latency spikes have stop since changing gateway. Not sure if that corrupts the outcome of your tests.
You are currently connected to gateway pcl-ag02.
RichardB
Seasoned Champion
Fixes: 39
Just spotted this & I have a TBB ping graph running with a link on http://community.plus.net/ping-graphs/
so now on PCL-AG02
Hope it helps Smiley
Here is my graph for yesterday 12-August, while on gateway PCL-AG01  -
I'm not convinced that the result is any better than any other day.   Undecided
Quote from: dave
We have a theory as to what's causing the problem based on some testing we've done in the labs and want to try out two possible fixes.
So next Monday we will be making some changes to PCL-AG01 and PCL-AG02 to see if we can improve this. Each one will have a different fix on it, like I say we've got 2 possible solutions so we want to try them both out.
After 33 gateway disconnect/connect sequences I have now swapped gateways to see whether the alternate gateway fix works any better for me.   Wink
[quote=Gateway Checker]Which gateway
