Little bit of giudence please..
- Little bit of giudence please..
Re: Little bit of giudence please..
02-09-2009 7:59 AM
If you can connect your computer via a network cable rather than wireless it might makes things easier.
02-09-2009 8:40 AM
Don't worry, I already posted your line stats earlier in this thread.
It looks like there might be a problem with your internal wiring. Can you make sure that your router connects to your master socket via a filter, making sure that all of the telephone sockets that are in use, also have a filter attached.
02-09-2009 9:00 AM
02-09-2009 1:26 PM
Quote from: mapletree If the stats are monitored continuously it might be easier to find the problem.
Using something like RouterStats.
You may need a little help setting this up so please ask.
06-09-2009 3:32 PM
Strat..I have hit on that link thank you...and I pulled up my router stats...how should I transer the information to here?
06-09-2009 3:44 PM
06-09-2009 4:01 PM
The files you can attach to the post are limited to jpeg, jpg, png, pdf
06-09-2009 10:14 PM
06-09-2009 10:31 PM
13-09-2009 2:11 PM
All hard connections checked and secure btw
I just checked my download speed and im Just slightly over 1.5 mbps...I have a feeling this has dropped since I forst moved to plusnet
15-09-2009 5:31 PM
Keep monitoring particularly for resync events.
Do a BT speedtest and it will tell you your IP profile. This should be 4500-5000 for the sync speed on your graph.
15-09-2009 9:21 PM
Right here you go.......
Download speedachieved during the test was - 1761 Kbps
For your connection, the acceptable range of speeds is 400-2000 Kbps.
Additional Information:
Your DSL Connection Rate :2816 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 2000 Kbps
16-09-2009 11:42 AM
Your sync speed is only 2816Kbps (when you ran that test). The profiling is about right for that speed.
16-09-2009 8:15 PM
I have tried a few different sites and they are all coming up at around 1.5-1.7 mbps...lets hope BT sort this exchange soon...its pretty slow compared to a lot of place...but im managing.
16-09-2009 8:46 PM
