Line reset
noddy8
Line reset
Hi is it possible to do a reset on my line it seems to have returned to a reasonably stable connection ( I hope ) cheers
12 REPLIES 12
MatthewWheeler
Fixes: 480
Re: Line reset
I've reset the line for you and it should go through in the next 4 hours.
Let us know how get on.
 Matthew Wheeler
noddy8
Re: Line reset
will do cheers
noddy8
Re: Line reset
I still don't understand why I have to reboot the router to get the new settings ? ? this was never needed with my last provider and IP profile increases automatically kicked in but not with Plusnet why is that ?
noddy8
Re: Line reset
did a re-sync but this can't be right
Home Image not loadedTesting Image not loadedResult Image not loaded
FAQ
Results Image not loaded
1. Best Effort Test: -provides background information.
  Download  Speed
  0.44 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
 Download speedachieved during the test was - 0.44 Mbps
 For your connection, the acceptable range of speeds is 0.6 Mbps-7.15 Mbps.
 Additional Information:
 Your DSL Connection Rate :3.84 Mbps(DOWN-STREAM), 0.45 Mbps(UP-STREAM)
 IP Profile for your line is - 3 Mbps
This test was not conclusive and further testing is required.This might be useful for your Broadband Service Provider to investigate the fault.
If you wish to carry out further tests,please click on 'Continue' button.If not, please close the window using 'Exit' button and contact your ISP for further assistance with these results.
Please visit the FAQ if you are unable to understand the test results.
MatthewWheeler
Fixes: 480
Re: Line reset
Was that over a wired or wireless connection?
Everything is set correctly on our end.
 Matthew Wheeler
noddy8
Re: Line reset
wired
noddy8
Re: Line reset
wondering if I should re-sync again ?
MatthewWheeler
Fixes: 480
Re: Line reset
I wouldn't as you're on 20cn and DLM may get the wrong idea.
Have you tried disconnecting and reconnecting within the routers interface? ^MW
 Matthew Wheeler
noddy8
Re: Line reset
not sure what you mean by that sorry
noddy8
Re: Line reset
if you mean disconnecting ethernet then yes tried it same speed by wireless too
noddy8
Re: Line reset
looking at system log looks like a admin disconnect from the exchange end but what ever it was it seems to have cured the download speed so here's hoping it stays stable cheers
HarryB
Fixes: 256
Re: Line reset
Glad to hear the speed is back to normal. Thanks for letting us know that's sorted.
 Harry Beesley
