Issue connecting blink system since changing to Plusnet
FIXED- Subscribe to RSS Feed
- Issue connecting blink system since changing to Pl...
3 weeks ago
Fixed! Go to the fix.
Re: Issue connecting blink system since changing to Plusnet
3 weeks ago - last edited 3 weeks ago
Its possible your Blink camera is 2.4ghz wifi only. The Plusnet Hub 2 uses the same SSID (wifi network name) for both 5ghz & 2.4ghz bands. Try disabling the 5ghz band temporarily using the Hub gui, connect the camera then re-enable the 5ghz band. That sometimes works. If it doesnt, then try changing the Wireless Mode from Mode 1 to Mode 2 or ebvn Mode 3. That improves compatibility with older/slower devices.
3 weeks ago
3 weeks ago
3 weeks ago
Have you tried a factory reset on the Blink device and set it up again from scratch?
3 weeks ago
3 weeks ago
You could try this
1) Turn the Hub Two wireless or switch off at the mains. This is to ensure all wireless signals are stopped
2) Using a mobile device create a 2.4GHz mobile hotspot that has the same SSID and password credentials as your Wi-Fi router.
3) Setup your smart device using the hotspot created above.
4) After the smart device is setup and is connecting shutdown your hotspot and turn your Hub wireless or device back on.
Hopefully this will resolve your issue
3 weeks ago
2 weeks ago
Sad to say for you I do use Apply products so I can not offer any assistance in enabling just 2.4GHz signal.
The option on my Android phone has been taken away to turn off 5 or 2.4GHz which is odd.
2 weeks ago
@PhilW888 I'm afraid I dont use Apple stuff either but these two links would seem to help.
The first describes how to setup the basic hotspot function and the second how to switch it between 2.4g & 5g
https://support.apple.com/en-gb/111785
https://www.idownloadblog.com/2020/11/04/iphone-personal-hotspot-wi-fi-bands-tutorial/
2 weeks ago
2 weeks ago
the Blink Support Team gave me something else to try, which involved a special reset to the Blink device.
Could you expand a little more on that please ? we see a few instances of these type of devices not connecting and any explanation may be useful to others in the future.
2 weeks ago
I followed these instructions. This finally prompted connection and a firmware update. I had to kinda repeat the process, as it ended up needing to be done twice:
1. Unplug the Sync Module and wait 30 seconds.
2. While unplugged, using a paperclip or similar item; press and hold the reset
button on the Sync Module.
3. Then plug it into power.
4. Continue holding the reset button until you see a flashing red light. Once
you see the flashing red, you can release the button.
5. Proceed to add the Sync Module.
Hope this helps others!
Phil
