Hub Two Router Continuously Flashing Orange Light
jslrahul
Hi Everyone,
Received confirmation message about broadband service is up and running after which I did setup the router. However, the router is continuously flashing Orange light after Green. Later, as per the guideline, I did check the cable connection both to the master socket and to the router and all looks good but still the router is flashing Orange light.
Can please suggest.
3 REPLIES 3
Legend
Fixes: 260
Re: Hub Two Router Continuously Flashing Orange Light
@jslrahul Check it now - it can take up to 23.59 for everything to mesh together on Plusnets side.
csmith94
Fixes: 29
Hi @jslrahul
Everything is now showing as active on your account, are you still seeing any issues or is everything ok now?
 Curtis Smith
jslrahul
Thank You for your time.
The issue was with OpenReach and it is fixed.
