How many people are using the upto 8mbps?
- Re: How many people are using the upto 8mbps?
- « Previous
- 1
- 2
- Next »
16-09-2007 7:11 AM
I went into the dsl-300G+ menu, which is modem (not the router) and found this information. Is this what I'm looking for?
PPP Information
Connection Type PPPoA
Encapsulation VC Mux
Login User Name curati@plusdsl.net
IP Address 87.114.66.41
Gateway 87.114.66.42
Connection Status Connected
PVC
VPI 0
VCI 38
ADSL Line Status
Operation Path Interleave
Operation Mode G.DMT
Upstream 704 Kbits
Downstream 5312 Kbits
Current Firmware Version
Current Firmware Version R2.05.b4t12uk
ADSL driver Version Annex_A(T.79.4.7)
PPP Information
PVC
VPI 0
VCI 38
ADSL Line Status
Upstream 704 Kbits
Message 16 of 23
(685 Views)
17-09-2007 3:50 PM
That explains a lot - the router is the DL-624 which doesn't have ADSL stats because it doesn't have an ADSL modem - that's over in the DSL-300G.
It looks like you have got the stats there and the good news is that you don't have to worry about upgrading - because you appear to have been upgraded already. You've got a downstream sync of 5312Kbs, which should be good for a 4500 profile. That upload speed looks odd though - what type of account are you on - is it a business account?
Message 17 of 23
(685 Views)
17-09-2007 4:15 PM
How about LLU
Message 18 of 23
(685 Views)
17-09-2007 4:26 PM
Completely OT but what does RIN stand for in your signature?
Quote from: Oldjim How about LLU
Message 19 of 23
(685 Views)
17-09-2007 4:28 PM
Hi Curati,
I think I might have found out what the problem with your speed may have been.
You are on a Tiscali LLU product, but our system, for whatever reason, had you down as being on a BT product, hence your speeds being capped to 2000Kbps, because it didn't know otherwise. so now I've told it that you're on the LLU product and then I've bumped up your profiled speed.
Can you try rebooting your hardware for me and seeing if you now manage to get a better throughput speed?
Message 20 of 23
(685 Views)
17-09-2007 4:45 PM
This is a trial running on PAYG where we are connecting directly to BT Central Plus bypassing the normal PlusNet servers - this link gives some detail http://usergroup.plus.net/forum/index.php/topic,4518.0.html
Quote from: lucerne Completely OT but what does RIN stand for in your signature?
Message 21 of 23
(686 Views)
17-09-2007 6:10 PM
Hi.
In answer to questions, I'm not on a business account, just the usual 14.99 a month.
I did a speed test with the plusnet speed tester and got 2635.9 kbps which is faster than before. Not quite upto 4.5 mbps but it's probably a busy time right now.
Thanks for the help
Thanks for the help
Message 22 of 23
(686 Views)
17-09-2007 8:20 PM
Quote from: James You are on a Tiscali LLU product
That would explain the upload speed then
At least there has been movement now, and hopefully a decent increase in speed for curati
Message 23 of 23
(686 Views)
- « Previous
- 1
- 2
- Next »
