How do I get target SNR fixed
- How do I get target SNR fixed
09-07-2009 8:51 PM
Borrowed a new router last Friday. Since then the speed gradually increased - but now it is stuck at about 6800 ish (see below) However the noise margin is 15dB plus. Presumably BT has set a high noise margin due to the dropouts - but this is not recovering. Connection has been stable now for a week. What do I need to do to get the noise margin set back to a lower value?
Thanks.
EDIT: My profile also climbed to 6000 - why has it now dropped to 4500 again even though the connection has been rock solid?
Note - prior to my disconnect problems I had a rock solid 8000+ connection without fail.
I would also like to get interleaving turned off.
ADSL Link Downstream Upstream
Connection Speed 6816 kbps 448 kbps
Line Attenuation 15.0 db 10.0 db
Noise Margin 15.8 db 22.0 db
Re: How do I get target SNR fixed
10-07-2009 7:58 AM
10-07-2009 12:57 PM
I simply think that due to the connection problems I had, that a target noise margin of 15dB has been set. This just a bit too high to achieve the maximum speed. Now my connection is stable it needs to bte set back to 6dB (as a target). Speed will increase to max, and noise margin will settle at about 10-13dB.
Question is - who can correct the target - or does it happe automatically in time.
25-07-2009 9:00 PM
How do I get this fixed?
26-07-2009 3:32 PM
26-07-2009 5:02 PM
26-07-2009 9:59 PM
27-07-2009 10:20 AM
I'll have a word with the faults team and see if there's anything we can do, though I know unfortunately that this is something it can be awkward to arrange. I'll let you know as soon as I know any more.
28-07-2009 8:40 AM
28-07-2009 9:02 AM
28-07-2009 11:42 AM
Thanks for your time on the phone earlier, please let us know if that doesn't sort it.
