High S/n margin since fault resolution
- Re: High S/n margin since fault resolution
05-07-2009 3:45 PM
Can anyone tell me how to get my target S/N margin reduced.
I was having MAJOR speed and stability problems that eventually proved to be a BT line fault (what a surprise - not) eventually fixed after no less than three BT engineer visits over the space of more than a month.
Anyway as part of their efforts to fix (hide) the problem BT kindly adjusted my SN margin - quote from fault ticket.
Dear Mr ********
BT have made recent changes to your SNR level. Once the local exchange starts seeing lengthy connections being made, the speed should gradually increase to the maximum the line will support. We advise you keep the router powered up and plugged in as much as you can and once the dynamic line management see's a stable connection, this will increase the line speed.
I have returned the ticket to yourself, which will keep the ticket open for 14 days and if there are any other issues, please update this ticket and we maybe able to test/advise further.
Kind regards,
I should add that this 'adjustment ' made little difference at the time - indeed it made matters worse
I don't have a speed problem as such now, but would like to get as much out of the line as possible.
My current router stats are:
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,840
Output Power (Up/Down) [dBm]: 12.0 / 19.5
Line Attenuation (Up/Down) [dB]: 13.5 / 25.0
SN Margin (Up/Down) [dB]: 23.0 / 15.0
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 264
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
Router is a Thomson TG585 v7 supplied by PN, plugged into a filtered faceplate (BT supplied) together with a single phone.
With 25.0 downstream attenuation, all advice seems to indicate that I should be able to sync at 8Mb with a downstream S/N margin of 6.
My margins seem to be very consistent - showing very little variation (<2db) whatever the time of day, weather etc
Thanks in advance for your help/ advice.
Cheers, Terry
06-07-2009 6:22 AM
06-07-2009 9:37 AM
It looks like the only thing that is preventing that is preventing you from receiving the full 8Mbps sync speeds is the fact that interleaving is turned on on your telephone line.
If you like I can place an order to remove interleaving from your line.
06-07-2009 8:45 PM
Thanks for the replies.
Sorry, Anotherone, I should have said "sync at 8Mb with a downstream S/N margin of 6db or more margin". Just lazy and couldn't be bothered to type it, I guess.
Thanks for your comment though
James - could you confirm that if turning off interleaving causes a problem I can have it turned back on again.
If so, could you go ahead and get it turned off for me.
Many thanks for your help both with this and with my previous challenges.
Cheers
Terry
07-07-2009 10:14 AM
As per the ticket I've just put on your account, I've placed an order to remove interleaving, which will complete tomorrow.
I'll have no issues with reversing the change, should it be problematic at all.
07-07-2009 10:34 AM
Thanks again, James
09-07-2009 10:22 AM
I have a similar problem with a High Noise Margin and consequent loss of speed.
For as long as I can remember my router has synced at 8128 with a Noise margin of 9dB (Attenuation 24 - 26 dB) - mybroadbandspeed would give 6.5 mbps. (Line Profile 7150)
This was so stable that I stopped checking it !
Recently (Sunday 28th June) my download speed dropped dramatially to 448 kbps. This stabalised by Monday 29th to 4.5 mbps. (Line profile 5000)
My router stats now are :
Downstream Upstream
Data rate(Kbps) 6656 832
Noise Margin 15 14
Attenuation(dB) 26 13
Briefly this last Monday (6th July) the downstream went to 7648 kbps / 12dB - but a thunderstorm and power cut put a stop to that and it returned to 6650 / 15.
I have been resyncing each day - with reference to the above should I just leave the router on and wait for the figures to improve and get my 8128 sync back, or do you need to take any action ?
My line is interleaved - will removing this improve things ?
Regards
Graham Cannon
09-07-2009 10:24 AM
Interleaving won't be affecting your sync speed to that degree.
Daily resyncs are a good idea. If it's not been sorted come tomorrow, give me a shoult and I'll get something raised with BT.
09-07-2009 10:35 AM
Thanks for the quick reply
I will come back to you with an update tomorrow.
Regards
Graham
10-07-2009 9:54 AM
Re-synced this morning - still 6592 / 15.
Can you get Bt to have a look at it ?
Graham
10-07-2009 10:22 AM
Just for my benefit, are you aware of anything that happened to cause your SNR to go considerably higher?
Fault on the line, increased noise and that sort of thing?
10-07-2009 12:25 PM
I might have found the cause of the problem
It seems that the master socket did not have the filter on it for some time ( - the router is connected to a BT fitted extension in my office) - this was apparently reconnected a couple of weeks ago so when I checked it when I noticed the issue it was in place and everything seemed OK 😞
I have tested the router at the extension and the master socket (now with filter) - no difference in syncing.
Sorry for not mentioning this earlier, but I have only just found out myself - I am now trying to explain the significance of the 'little white box' to my wife
I presume that the increased noise on the line due to not having the filter could be that cause of the problem ?
Regards
(A red-faced) Graham
10-07-2009 2:58 PM
That almost definitely will be the cause. Good spot
11-07-2009 2:16 PM
Quote from: Jameseh Hi Terry,
Thanks again, James - seems to have done the trick with no issues so far. Have been synced at 8Mb for 3days+ now with SN margin always 12.5-13.5db. BT profile has just gone up to 7150.
Just waiting for PN to follow suit now.
Cheers, Terry
13-07-2009 3:02 PM
It looks like our profiling changed around 6pm on Saturday.
