Help!!
- Help!!
- « Previous
- 1
- 2
- Next »
Re: Help!!
24-11-2014 5:19 PM
DSL Connection
Link Information
Uptime: 0 days, 0:01:21
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 1,155 / 11,835
Data Transferred (Sent/Received) [kB/kB]: 88.97 / 364.42
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 22.7 / 41.5
SN Margin (Up/Down) [dB]: 6.4 / 3.1
Loss of Link (Remote): -
Error Seconds (Local/Remote): 15 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 96
HEC Errors (Up/Down): 0 / 1,372
jim:quote
Re: Help!!
24-11-2014 5:25 PM
Your internal wiring is the problem
Compare
Bandwidth (Up/Down) [kbps/kbps]: 1,107 / 2,091
with
Now to try and sort that out unless you can keep using the test socket
I suspect that whoever put in 10 extension sockets made a complete pigs breakfast of it
Can you post a picture of the lower faceplate you removed to show the wiring attached to it
Re: Help!!
24-11-2014 5:50 PM
By the way if I used the test socket (in Hall) Which is a long way away from our preferred location why is it that when I carry out a speed test it still remains the same, and will it make a difference if I tested each socket separately?
Re: Help!!
24-11-2014 5:59 PM
Re: Help!!
24-11-2014 6:09 PM
The current synch speed is way over a reasonable expectation for your line. The error counts need to be watched as a 3dB SNRM might be a bit too low for the line.
Re: Help!!
24-11-2014 6:55 PM
Unfortunately you lost me there far to technical.
But I will persevere.
Regards
Re: Help!!
24-11-2014 7:02 PM
Don't know if that would make any difference.
Re: Help!!
24-11-2014 7:06 PM
If it was a non UK phone then it should be OK providing you have a filter between it and the phone socket
Re: Help!!
24-11-2014 7:21 PM
Re: Help!!
24-11-2014 8:02 PM
With star wiring, one wire goes to a point from which are run more than one wire to other sockets.
Re: Help!!
25-11-2014 9:40 AM
Quote from: Oldjim The speed test will remain the same as the Plusnet profile here won't have updated https://portal.plus.net/my.html?action=data_transfer_speed you may find it has changed over night
It updated at 3.45am this morning. However there was no PPP drop again (I'll add to problem).
@p147
Can you log in to your router and press disconnect, wait 30 seconds and then connect. You should see some better speeds coming through then.
Re: Help!!
25-11-2014 10:58 AM
Thank You
Paul
Re: Help!!
25-11-2014 11:03 AM
Glad to hear that it's sorted for you - thank you for posting back the good news.
Kevin
Re: Help!!
25-11-2014 11:06 AM
That is what the Forums are here for (not just for all the wittering in Chit Chat although you are welcome to join in if you feel so inclined)
Re: Help!!
25-11-2014 11:22 AM
And Oldjim
- « Previous
- 1
- 2
- Next »
