Fibre extension kit
- Fibre extension kit
Fibre extension kit
27-09-2013 6:45 PM
Apologies if this issue has been raised before.
I am shortly to be connected to unlimited fibre, with the order comes a fibre extension kit which I understand can be x meters from the bt Socket. Currently I have a filter atached to the master socket to feed my telephone and router. I plan to have the extension routed to the living room instead of the front lobby, does plusnet have a diagram of this with + cables required etc .
Regards
Regards
Message 1 of 3
(999 Views)
2 REPLIES 2
Re: Fibre extension kit
29-09-2013 12:42 AM
Ok managed to solve this problem
Message 2 of 3
(398 Views)
29-09-2013 8:34 AM
Hey rsinbad.
Glad to hear you now have this sorted. A fibre extension kit that the engineers we send out would supply a 30m CAT5e cable (Ethernet). That's all it is, this is simply to extend the range between the router and Openreach Modem.
Hope this helps.
Dean
Hope this helps.
Dean
Message 3 of 3
(398 Views)
