FTTC slow download, fast upload
- Re: FTTC slow download, fast upload
25-09-2013 1:40 PM
As soon as we connected my laptop to the new router via ethernet, the engineer did a ping test to www.bbc.co.uk (~25ms) and checked iPlayer could stream ok (it could). After he left I wanted to do a speed test so I visited both speedtest.net and the BTW Performance Test site, both of which give very similar results showing my download was actually slower than I used to get on ADSL but my upload was looking really good.
Download speed (Mbps): 9.51
Upload speed (Mbps): 15.11
Ping Latency (ms): 36.63
Now, I understand that speeds can vary wildly over the first few days as the line trains but I have done frequent speed tests over the last 24 hours or so and these figures seem to be pretty much set in stone, varying only by a few kilobits per second each time.
I'm a little concerned that my line seems to have settled on a really slow downstream and isn't training properly, even though my upload is close to its optimum and actually much faster than my downstream.
Am I being impatient and need to give it the whole 10 days to train or could there be another reason my downstream is so slow yet my upstream looks really good?
Edit: I forgot to attach the Plusnet estimated and actual connection speed as reported in the member centre.
Estimated line speed: 60Mb (Download speed could vary depending on line conditions. Estimates are the maximum speeds that your phone line can support. These speeds are dependent on the package you choose.) - Checked on 2013-08-24 12:10:27
Current line speed: 10.1 Mb
25-09-2013 1:56 PM
Also, tried just connecting wired into the Openreach modem, creating connection and testing?
Edit: Sorry, read wired
![Smiley Smiley](/html/@39650D28FE4EA73A5BA77CFD0A477003/images/emoticons/smiley.gif)
I had some speed issues for first few days running at 7.7Mbps when I should be around 40-45Mbps. After 2 days, improved and shot to 46Mbps.
25-09-2013 2:07 PM
I'd definitely recommend trying a direct connection to the modem, if it still the same I'd then get a fault raised: http://faults.plus.net
25-09-2013 2:14 PM
Quote from: All4One Wireless or wired?
Wired.
Quote from: All4One Also, tried just connecting wired into the Openreach modem, creating connection and testing?
I haven't tried that. Is it as simple as connecting my laptop to the modem via ethernet and using DHCP to get an IP, etc? Or do I need to set any particular network settings on the laptop when doing this?
Quote from: All4One I had some speed issues for first few days running at 7.7Mbps when I should be around 40-45Mbps. After 2 days, improved and shot to 46Mbps.
Ahhh, good to hear things may just take a little time to improve significantly.
Did you reboot your modem / router at all during that time?
25-09-2013 2:16 PM
Quote from: _Adam_Walker_ Hi.
Ok, I will try this in next few minutes and post back here. Do I need to use any particular network settings when connected directly to the modem, or will DHCP on my laptop still work?
25-09-2013 3:06 PM
Quote from: monksteve Current line speed: 10.1 Mb
The plusnet profile has not updated after your fttc install and will be restricting your speed (should be set at 78 Mb for a new 80/20 install) - once that is changed you should be all set.
![Wink Wink](/html/@ED8EAB3707DE077FFF94EEBAB958E3C6/images/emoticons/wink.gif)
Hopefully one of the support guys here will spot this and update it or alternatively you could give support a ring and ask them to update it.
25-09-2013 3:53 PM
25-09-2013 4:07 PM
I'm now getting speeds of 71 Mbps downstream, 16 Mbps upstream, which puts a big smile on my face.
26-09-2013 9:51 PM
I have exactly the same issue as Monksteve (thanks Monksteve for raising this, good to know I'm not alone!).
Many thanks for your help,
Tony.
27-09-2013 10:46 AM
27-09-2013 6:35 PM
Yes, he was really helpful. Many thanks for your reply.
Have a good weekend.
Tony.
