FTP Service ??? Cancelled ??
- FTP Service ??? Cancelled ??
06-09-2009 12:34 AM
Well - - what happen to the ftp upload Service ?
i understand that plusnet has got a premium service for that - - so pay more if you want ftp -
as it is - offered on standard basis - from 12 pm to 2 am or so it is basically useless and impossible to use - there is simply no speed at all and connecting to servers is an impossible task !! line drops - connections failures etc etc and jokes type speed of 3 to 5 kb sec !!
this is causing lots of distress - waste of time - etc etc very unhappy about this !!
come on plus net - get it right - - do not be too tight ! - and give us just a touch more to make ftp actually usable !! - -
ray
jim:blue excessive smileys removed as per forum rules mod:end
ray
Message 1 of 5
(2,528 Views)
4 REPLIES 4
Re: FTP Service ??? Cancelled ??
06-09-2009 7:27 AM
are you talking about external FTP ? as that is treated as a download type site and is restricted, see comparison between Value and unlimited below, Pro is not restricted
Message 2 of 5
(512 Views)
08-09-2009 1:12 AM
Hi Pierre;
tx for reply -
very likely yes - called external - im try to connecting to dedicated servers and connections are really hard to get and slow most of the time ! upload of files etc etc -
im on unlimited package - very good for browsing / download - ! but very slow on ftp ! - very hard to use ftp :
look:
Command: PASV
Response: 227 Entering Passive Mode (204,27,57,133,181,249).
Command: APPE PDFsurfer.psd
Response: 150 Opening BINARY mode data connection for PDFsurfer.psd
Error: Connection timed out
Status: Connecting to 204.27.57.133:21...
Status: Connection established, waiting for welcome message...
Error: Could not connect to server
Status: Delaying connection for 5 seconds due to previously failed connection attempt...
Response: 220 ProFTPD 1.3.1 Server ready.
Command: USER raimondo03
Response: 331 Password required for raimondo03
Command: PASS ********
Response: 230 User raimondo03 logged in
Status: Connected
Status: Starting upload of F:\sites\pdfsurfer\httpdocs\includes\search_form.php
Command: CWD /domains/pdfsurfer.com/public_html/includes
Response: 550 /domains/pdfsurfer.com/public_html/includes: No such file or directory
Response: 250 CWD command successful
Command: MKD includes
Response: 257 "/domains/pdfsurfer.com/public_html/includes" - Directory successfully created
Command: PWD
Response: 257 "/domains/pdfsurfer.com/public_html/includes" is the current directory
Status: Retrieving directory listing...
Command: TYPE I
Response: 200 Type set to I
Command: PASV
Response: 227 Entering Passive Mode (204,27,57,133,166,38).
Command: LIST
Response: 150 Opening ASCII mode data connection for file list
Response: 226 Transfer complete
Command: PASV
Response: 227 Entering Passive Mode (204,27,57,133,206,163).
Command: STOR search_form.php
Response: 150 Opening BINARY mode data connection for search_form.php
Status: File transfer successful
Status: Starting upload of F:\sites\pdfsurfer\httpdocs\includes\functions.php
Command: PASV
Response: 227 Entering Passive Mode (204,27,57,133,230,106).
Command: STOR functions.php
Response: 150 Opening BINARY mode data connection for functions.php
Status: Connected
Status: Starting upload of F:\sites\pdfsurfer\httpdocs\includes\doc_bottom.php
Command: TYPE I
Command: PASV
Response: 227 Entering Passive Mode (204,27,57,133,144,195).
Command: STOR doc_bottom.php
Response: 150 Opening BINARY mode data connection for doc_bottom.php
Status: Starting upload of F:\sites\pdfsurfer\httpdocs\includes\config.php
Command: PASV
Response: 227 Entering Passive Mode (204,27,57,133,217,121).
Command: STOR config.php
Response: 150 Opening BINARY mode data connection for config.php
Status: Starting upload of F:\sites\pdfsurfer\httpdocs\includes\adbottom1.php
Command: PASV
Response: 227 Entering Passive Mode (204,27,57,133,150,223).
Command: STOR adbottom1.php
Response: 150 Opening BINARY mode data connection for adbottom1.php
Status: Starting upload of F:\sites\pdfsurfer\httpdocs\includes\with Adsense doc_top.php
Command: PASV
Response: 227 Entering Passive Mode (204,27,57,133,160,176).
Command: STOR with Adsense doc_top.php
Response: 150 Opening BINARY mode data connection for with Adsense doc_top.php
Status: Starting upload of F:\sites\pdfsurfer\httpdocs\includes\doc_top.php
Command: PASV
Response: 227 Entering Passive Mode (204,27,57,133,168,195).
Command: STOR doc_top.php
Response: 150 Opening BINARY mode data connection for doc_top.php
Command: PASV
Response: 227 Entering Passive Mode (204,27,57,133,148,234).
Command: LIST
Status: Directory listing successful
Status: Disconnected from server
Status: Waiting to retry...
Status: Delaying connection for 1 second due to previously failed connection attempt...
you can see that it is very or nearly impossible to keep a stable ftp running - or even connecting to servers !
this is happen on many servers - so it is not a server problem .
ray
tx for reply -
look:
Command: PASV
Status: Connected
Command: PWD
Command: TYPE I
Command: PASV
Command: LIST
Command: PASV
Command: PASV
Status: Connected
Command: TYPE I
Command: PASV
Command: PASV
Command: PASV
Command: PASV
Command: PASV
Command: PASV
Command: LIST
ray
Message 3 of 5
(512 Views)
08-09-2009 9:43 AM
That is very odd as upstream speeds aren't capped
Note - do you want to edit out the username
You don't say which ftp program you are using but as a quick check would it be possible to do a test using FireFTP on Firefox as I haven't seen that problem uploading to my 1&1 site
Message 4 of 5
(512 Views)
08-09-2009 7:52 PM
good day
the ftp program is the Filezilla -
let me add also - last night - at exactly 2 am - and as all night - the speed and connectivity all the sudden become i would say norma - very good uploading at 420 kb/sec - - and this happen every night after 2 am exactly - - all the sudden at 2.01 am sec ftp speed go up - - it than goes back to 10 - 8 kb/sec in the morning 10 - 11 am or so - and connectivity become really bad.
ray
ray
Message 5 of 5
(512 Views)
