FAO James et all
- FAO James et all
Re: FAO James et all
01-10-2009 2:15 PM
06-10-2009 10:36 PM
My connection managed to remain stable for six days. My target SNR reduction lasted two disconnects and has been raised back to 15 again.
Then somebody from Plusnet tries to fob me off (and enrages me) by telling me my problem is fixed because it can manage a few days connected. Target SNR reductions occur after 28 days of stable connection. So, if the best to date I can manage is 6 days then I'll never have a reduction.
All this after I switched home phone over to make it easier to find and repair the fault too. I've really made a bad choice here I feel now. I couldn't possibly recommend a BTW based broadband supplier to anyone.
07-10-2009 3:18 AM
I have noticed since last week my speed has dropped from 6.4kbps down to 5.4kbps I did the speed test at 3am so not many people on line but its still slower
Nothing changed my end whats going on plusnet?
Puddy
07-10-2009 9:45 AM
As far as broadband connectivity goes, you don't have a problem, it is working.
Sorry to see that the SNR picked up again - do you have a router which is compatible with the DMT tool?
When I mentioned a period of stability for 28 days, I didn't mean that your uptime needed to be 4 weeks straight, just that you don't encounter periods of instability.
07-10-2009 10:01 AM
Quote When I mentioned a period of stability for 28 days, I didn't mean that your uptime needed to be 4 weeks straight,.........................
In my experience , it does
07-10-2009 10:15 AM
07-10-2009 10:20 AM
[hides]
07-10-2009 10:21 AM
07-10-2009 11:18 AM
07-10-2009 11:22 AM
07-10-2009 11:23 AM
07-10-2009 1:52 PM
07-10-2009 1:59 PM
07-10-2009 2:14 PM
Hope that helps,
07-10-2009 2:28 PM
I just want to try tweaking target margin myself to see if I can get higher speeds without problems. None of my current routers allow this to be changed.
