Download/upload speed as halved
Azagoth
Before I went to bed I was at my usual speed of around 8-9Mbps down and 1Mbps up, I've just got up and now I'm at half of that.  Also websites that are usually instant to load are taking anywhere from a minute to load, assuming the load and don't time out.  Gaming is a no go too.
7555911486
My internet hasn't dropped overnight, it's showing as being up for 6Day(s) 10:48:44 with the same sync values.
Line Rate - Upstream (Kbps): 1187
Line Rate - Downstream (Kbps): 10199
So why have my speeds halved?
3 REPLIES 3
Azagoth
Re: Download/upload speed as halved
This is an absolute joke.  Trying to download some photo and video files before I go to work and the speed has dropped down to less than 20kB/s, it's basically unusable.  It's just taken a minute for this thread to open and then another minute for the reply box.
JayG
Fixes: 6
Given your sync rates still look good, have to ask whether your speedtest was done wired or wireless?
adamwalker
Fixes: 221
I've just been running diagnostics but everything is looking fine. I'd definitely try testing speeds over a wired connection if you haven't done so already.
 Adam Walker
