De-queue mail form autoturn
- Re: De-queue mail form autoturn
09-07-2009 10:13 AM
Hi
Mail main server has been of line for a week the runs on my ADSL connection. When trying the finger command - i get a error.
Any ideas?
Thanks Phil
C:\Documents and Settings\Phil.WINXP2>finger postmaster@autoturn.plus.net
[autoturn.plus.net]
> Finger: read::Connection reset by peer
Any ideas?
Thanks Phil
Message 1 of 8
(1,760 Views)
7 REPLIES 7
10-07-2009 8:17 AM
Anyone?
Message 2 of 8
(662 Views)
10-07-2009 9:28 AM
Phil, you haven't got an autoturn directory on our systems:
I notice there's a manual record setup on your domain that points to our autoturn servers, however the entry is only created on our systems if your mail delivery is set to SMTP on the portal.
From what I can tell it isn't and instead it's set to 'Other'.
autoturn-info for 212.159.xxx.xxx:
[ * ] no directory or maildir for this IP!
Message 3 of 8
(662 Views)
10-07-2009 9:50 AM
Thanks Bob
Changed to SMTP now - how long will the change need to be applied?
Phil
Phil
Message 4 of 8
(662 Views)
11-07-2009 8:59 AM
Hi Bob
Could you check from your end again - still getting the same error?
Phil
Phil
Message 5 of 8
(662 Views)
11-07-2009 9:09 AM
Do you know whether you have any emails queued? From memory I thought the message you are seeing was normal for an empty queue but testing mine at the moment it return my IP address which I can't remember it use to for an empty queue.
Message 6 of 8
(662 Views)
11-07-2009 11:58 AM
Hi
There should not be any but thats why I was asking if Bob could check at PN's end to see if setup - if confirmed is setup, i will test by sending a mail with my MTA off-line.
Phil
Phil
Message 7 of 8
(662 Views)
12-07-2009 10:45 AM
Unfortunately I can't remember how to check that at the moment, I'll speak to Bob in the morning when I'm back in the office and ask him to check again.
Message 8 of 8
(662 Views)
