DSL connection problems / very slow broadband
- DSL connection problems / very slow broadband
13-04-2020 4:04 PM
Hello
I have been having problems since yesterday with the DSL link going down on my router. When the connection is restored the broadband speed is very slow - down to 10 kbps. Could you check the line to see if there is a fault in the BT network.
Geoff
Re: DSL connection problems / very slow broadband
13-04-2020 5:52 PM
Hi @GCotterill
Sorry to hear this.
I've tested the line today but unable to find a fault that would be causing these issues. Could you please follow our trouble shooting guide so that we can try and rule out the cause being something internal? If the problem persists please raise a fault here with us.
13-04-2020 9:32 PM
Hello Katie
Thanks for looking into this problem. Since you checked it the speed has improved significantly.
Geoff
14-04-2020 10:25 AM
Hi Katie
The connection has gone back to dropping out and running at low speeds in between. It did improve significantly last night after you checked the line but the problem has returned. I understand the systems are under a lot of pressure but I could do with a more stable connection to work from home. I don't expect the maximum download speed but if it could be above 500Kbps I could manage through this period.
Geoff
14-04-2020 2:44 PM
Hi @GCotterill,
I'm sorry to hear that you're still experiencing problems with your connection. Testing your line is showing that your line is currently banded to a maximum of 288k but hasn't picked up any other issues. As this is the case, I have reset the line to try and resolve this problem. Please allow 24 hours for this to take effect and let us know if the issue persists.
