DNS weirdness
- Re: DNS weirdness
Re: DNS weirdness
08-07-2009 3:15 PM
Re: DNS weirdness
08-07-2009 3:27 PM
It is not acceptable to advise me to specify some other DNS server because that prevents me from accessing the web via the proxy server at work.
The link that Bob posted http://usertools.plus.net/@gateway tells me:
"Records show your IP address is not that from the PlusNet brand and as such, we cannot detect your gateway. The results below may be skewed somewhat as a result.
You are currently connected to the "City Lifeline, Juniper 9" gateway. This gateway is sometimes known as pcl-ag02.
This is because it appears you are not a PlusNet Customer."
This statement is not correct, though it may well become so in the near future.
As I am paying more for this connection than I would for BT, talk-talk, Tiscali etc I expect a better service than I would get from those ISPs
Re: DNS weirdness
08-07-2009 3:46 PM
Quote from: Bob Anyway, quick update...
Four of the servers at one of the sites you connect to for DNS resolution keep on failing TCP/IP heathchecks in the load balancer.
Bob
This hasn't started recently, it's been going on for weeks. I first raised a ticket on 16th June - not that that was the start of it - it just got worse then, but I gave up with it as the responses were less than helpful. The problem is at it worst at the busiest times of the day, mid-morning, late afternoon/early evening and again just after midnight. I think the increased iPlayer traffic has also had a large part to play in it.
I have PuTTY running constantly, monitoring my asterisk server, and spot the problems straight away as they happen, registrations timing out or failing completely and extensions becoming lagged or unreachable, etc.
I am using 212.159.6.10 and 212.159.13.50 at the present time but have tried various combinations over the last few weeks.
Re: DNS weirdness
08-07-2009 4:09 PM
My results:
Microsoft Windows [Version 6.0.6002]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Bazza>tracert 212.159.6.9
Tracing route to ptn-cdns01.plus.net [212.159.6.9]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 192.168.1.1
2 36 ms 34 ms 30 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 38 ms 30 ms 31 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 30 ms 31 ms 29 ms ae0-102.ptn-gw01.plus.net [212.159.1.53]
5 31 ms 43 ms 57 ms vl55.ptn-lb01.plus.net [212.159.2.124]
6 30 ms 64 ms 37 ms ptn-cdns01.plus.net [212.159.6.9]
Trace complete.
C:\Users\Bazza>tracert 212.159.6.10
Tracing route to ptn-cdns02.plus.net [212.159.6.10]
2 35 ms 41 ms 37 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 37 ms 43 ms 29 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 47 ms 73 ms 80 ms ae0-102.ptn-gw01.plus.net [212.159.1.53]
5 30 ms 88 ms 36 ms vl55.ptn-lb01.plus.net [212.159.2.124]
6 29 ms 28 ms 29 ms ptn-cdns02.plus.net [212.159.6.10]
Trace complete.
C:\Users\Bazza>nslookup bbc.co.uk 212.159.6.9
Server: ptn-cdns01.plus.net
Address: 212.159.6.9
Non-authoritative answer:
Address: 212.58.254.252
C:\Users\Bazza>nslookup bbc.co.uk 212.159.6.10
Server: ptn-cdns02.plus.net
Address: 212.159.6.10
C:\Users\Bazza>
Re: DNS weirdness
08-07-2009 4:15 PM
If your tracert's complete in a reasonable time, which they have, then this isn't a problem.
If you've got problems then usually one or two hops will be shown with * * * meaning they've timed out.
Re: DNS weirdness
08-07-2009 4:21 PM
Re: DNS weirdness
08-07-2009 4:31 PM
Quote from: jelv You don't have to change it in your router. Change the network settings on your PC to use the DNS servers you want.
Thanks Jelv, I've forced mine to change to a different DNS server and I seem to have most things back BUT.... when this started at the weekend, my newsreader started throwing up connection errors and that's not gone away. Is it just a coincidence?
Re: DNS weirdness
08-07-2009 4:37 PM
2 35 ms 29 ms 31 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 30 ms 29 ms 42 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 131 ms 161 ms 205 ms ae0-102.ptn-gw01.plus.net [212.159.1.53]
5 32 ms 30 ms 29 ms vl55.ptn-lb01.plus.net [212.159.2.124]
6 58 ms 61 ms 45 ms ptn-cdns01.plus.net [212.159.6.9]
2 32 ms 46 ms 32 ms lo0-plusnet.thn-ag3.plus.net [195.166.128.80]
3 33 ms 30 ms 47 ms vl303.thn-gw1.plus.net [84.92.3.177]
4 72 ms 237 ms 173 ms ae0-102.ptn-gw01.plus.net [212.159.1.53]
5 36 ms 33 ms 44 ms vl55.ptn-lb01.plus.net [212.159.2.124]
6 32 ms 29 ms 51 ms ptn-cdns01.plus.net [212.159.6.9]
Re: DNS weirdness
08-07-2009 4:39 PM
Ok, spoke too soon. Nothing's changed at all. My only access is via this dog-slow proxy.
Are Plusnet going to give customers a refund for this non-service?
Re: DNS weirdness
08-07-2009 4:44 PM
The second scan is after I dropped and reconnected the ADSL connection and shows a marked improvement in DNS resolution times (2.59s compared with 19.58s):
[tt]Completed Traceroute at 16:25, 0.08s elapsed
Initiating Parallel DNS resolution of 12 hosts. at 16:25
Completed Parallel DNS resolution of 12 hosts. at 16:26, 19.58s elapsed
DNS resolution of 6 IPs took 19.58s. Mode: Async [#: 2, DR: 1, OK: 5, NX: 0, SF: 0, RF: 0, NI: 0, NA: 0, TR: 8, TO: 16, TX: 21, CN: 0]
Host ptn-cdns01.plus.net (212.159.6.9) is up, received echo-reply (0.031s latency).
TRACEROUTE (using proto 1/icmp)
HOP RTT ADDRESS
1 0.00 me
2 31.00 lo0-plusnet.pcl-ag02.plus.net (195.166.128.39)
3 31.00 gi1-2-904.pcl-gw02.plus.net (84.92.0.141)
4 31.00 vl63.pcl-lb01.plus.net (212.159.2.252)
5 31.00 ptn-cdns01.plus.net (212.159.6.9)
Host ptn-cdns02.plus.net (212.159.6.10) is up, received echo-reply (0.016s latency).
HOP RTT ADDRESS
1 -- me
2 -- lo0-plusnet.pcl-ag02.plus.net (195.166.128.39)
3 -- gi1-2-904.pcl-gw02.plus.net (84.92.0.141)
5 31.00 ptn-cdns02.plus.net (212.159.6.10)
Read from C:\Program Files\Nmap: nmap-protocols.
Nmap done: 2 IP addresses (2 hosts up) scanned in 28.95 seconds
Raw packets sent: 16 (448B) | Rcvd: 30 (1064B)[/tt]
Second scan:
[tt]Completed Traceroute at 16:28, 0.13s elapsed
Initiating Parallel DNS resolution of 12 hosts. at 16:28
Completed Parallel DNS resolution of 12 hosts. at 16:28, 2.59s elapsed
DNS resolution of 7 IPs took 2.59s. Mode: Async [#: 2, DR: 0, OK: 7, NX: 0, SF:0, RF: 0, NI: 0, NA: 0, TR: 7, TO: 2, TX: 9, CN: 0]
Host ptn-cdns01.plus.net (212.159.6.9) is up, received echo-reply (0.016s latency).
HOP RTT ADDRESS
1 0.00 me
2 31.00 lo0.plusnet.thn-ag1.plus.net (195.166.128.101)
3 32.00 vl703.thn-gw1.plus.net (84.92.4.241)
4 32.00 ae0-102.ptn-gw01.plus.net (212.159.1.53)
5 32.00 vl55.ptn-lb01.plus.net (212.159.2.124)
6 31.00 ptn-cdns01.plus.net (212.159.6.9)
Host ptn-cdns02.plus.net (212.159.6.10) is up, received echo-reply (0.015s latency).
HOP RTT ADDRESS
1 -- me
2 -- lo0.plusnet.thn-ag1.plus.net (195.166.128.101)
3 -- vl703.thn-gw1.plus.net (84.92.4.241)
4 -- ae0-102.ptn-gw01.plus.net (212.159.1.53)
5 -- vl55.ptn-lb01.plus.net (212.159.2.124)
6 32.00 ptn-cdns02.plus.net (212.159.6.10)
Nmap done: 2 IP addresses (2 hosts up) scanned in 3.27 seconds
Edited to add the command I used:
[tt]nmap -sP -PE --traceroute -d 212.159.6.9-10[/tt]
Re: DNS weirdness
08-07-2009 4:58 PM
Quote from: Forest
Or better still cancel our contracts so we can move elsewhere
Re: DNS weirdness
08-07-2009 5:03 PM
I will monitor things here until Plusnet have sorted this service affecting issue out.
Re: DNS weirdness
08-07-2009 5:22 PM
Now I'm getting these problems as well. Started about 10 mins ago, just as I darn well needed the internet as well.
Regards
Danep
Re: DNS weirdness
08-07-2009 5:24 PM
Tracing route to 212.159.6.9 over a maximum of 30 hops
2 30 ms 29 ms 30 ms 195.166.128.80
3 48 ms 43 ms 32 ms 84.92.3.177
4 33 ms 41 ms 35 ms 212.159.1.53
5 30 ms 30 ms 37 ms 212.159.2.124
6 38 ms 29 ms 32 ms 212.159.6.9
Trace complete.
Tracing route to 212.159.6.10 over a maximum of 30 hops
2 43 ms 29 ms 37 ms 195.166.128.80
3 34 ms 33 ms 37 ms 84.92.3.177
4 35 ms 31 ms 32 ms 212.159.1.53
5 38 ms 45 ms 32 ms 212.159.2.124
6 33 ms 53 ms 31 ms 212.159.6.10
Trace complete.
DNS request timed out.
timeout was 2 seconds.
Server: UnKnown
*** Request to UnKnown timed-out
Server: UnKnown
C:\Users\Bazza>
Re: DNS weirdness
08-07-2009 5:32 PM
2 31 ms 30 ms 31 ms lo0.plusnet.thn-ag1.plus.net [195.166.128.101]
3 192.168.1.1 reports: Destination net unreachable.
Trace complete.
2 44 ms 30 ms 41 ms lo0-plusnet.pcl-ag01.plus.net [195.166.128.27]
3 40 ms 32 ms 31 ms gi1-2-803.pcl-gw1.plus.net [84.92.5.57]
4 42 ms 82 ms 58 ms vl63.pcl-lb01.plus.net [212.159.2.252]
5 30 ms 36 ms 44 ms ptn-cdns02.plus.net [212.159.6.10]
Trace complete.
C:\Users\Bazza\nslookup bbc.co.uk 212.159.6.9
C:\Users\Bazza>
