DNS cannot find server - errors
- DNS cannot find server - errors
04-01-2010 5:29 PM
to be honest i cant remember if i had the same problem with the old router as i had been having loads of problems with my line anyway.
could this be an issue with the new router or settings
many thanks
Re: DNS cannot find server - errors
04-01-2010 5:44 PM
Well it works for me.
You could hard code the ip addresses of the Plusnet DNS servers into your PC, or into your router (if you have a static ip address).
Details in https://portal.plus.net/my.html?s=0&action=refresh_browser
04-01-2010 6:15 PM
strange, i dont really understand what a DNS error is though
04-01-2010 6:21 PM
Basically, DNS="Domain Name System" is a service that converts a web site name into an ip address (by doing a lookup on a computer at a known ip address).
05-01-2010 8:06 AM
ta
05-01-2010 8:15 PM
i'll monitor it and see how i go
thanks for help
05-01-2010 11:49 PM
Any benefit from doing this would be very marginal though.
06-01-2010 8:18 AM
takes a bit of getting used to i suppose
cheers
06-01-2010 11:23 AM
If so, change it to 0 (zero) = forever.
06-01-2010 5:44 PM
thanks for your advice and help, much appreciated
