DLM reset request
- Re: DLM reset request
DLM reset request
29-07-2018 12:57 PM
Hello
I was having adsl modem problems 3-4 weeks ago which resulted in a lot of reconnections which I have since fixed, It seems DLM has firmly fixed itself at a low connection speed now and will not budge.
Could I request a DLM reset please.
current stats are below
Current Rate(kbps) 1083 568 Max Rate(kbps) 1088 4328 SNR Margin(dB) 6.9 31.6 Line Attenuation(dB) 27.9 44 Errors(pkts) 465 3702
30-07-2018 12:19 PM
Hi Anne, I have placed the reset request for you and this should have an effect in the next couple of hours. Please restart your router after 2pm to pull through a new connection with the updated profile.
If you need any further help please do not hesitate to get back in contact.
