Could you please uncap my upload speed?
FIXED- Subscribe to RSS Feed
- Re: Could you please uncap my upload speed?
31-08-2017 10:18 PM
Fixed! Go to the fix.
01-09-2017 9:03 AM
02-09-2017 10:28 AM
Is that correct? - And would I have switch off the router or can I leave it switched on for this to come into effect?
02-09-2017 4:21 PM
It looks like the agent submitted the order through your account to be processed automatically, which means the order should complete 5 working days later. Instead of manually submitting it through to BTwholesale as that way it can be done within 1 working day.
The order is due to complete on 8th Sept. Many apologies for the inconvenience caused.
02-09-2017 5:24 PM
@Gandalf - Thanks for the response. And fortunately the upload speed is not too much of a concern at the moment. And I'd like to add the PN advisor was really helpful. No problems whatsoever.
And re. the download speed; there were problems with it. Even though at the time the synch showed about 18MB, the speed was way lower than what it should have been. I used the 2704n router (wired connection using the master/test socket) and it was at least 6-7 meg off (of) what I should be receiving. I did the same thing again but this time with an old TG582n router and the speed magically increased to about 17 meg (which is consistent with about 19/20 MB synch).
Sadly it's not the first time the 2704n router has let me down. I had another one and the same thing happened with that as well.
I'm just wonderring whether the Hub 0 (2704n) isn't really 'made' for high speeds. I also note the Hub 1 is mainly for fibre. If I ever was to use one of those, would it work on a normal ADSL line?
03-09-2017 1:15 PM
That's good to hear, he's one of my colleagues.
We used to send out Hub Zero's for fibre installations before we released the Hub One. I personally had a Hub Zero on my fibre connection and it handled 50mbps well. We could try sending you a replacement?
Yeah the Hub One works for both ADSL and VDSL.
03-09-2017 2:23 PM
@Gandalf - Would it be possible to send out a Hub 1 instead of a Hub 0? - If so, would I just pay the postage which i assume is still £6.99?
Thanks.
03-09-2017 2:29 PM
We'd only cover the cost of the Hub One [£99.99] on a fibre contract I'm afraid. Having said that it may be worth discussing this with our Customer Options Team on 0800 013 2632 [Selecting Option 1, then Option 2].
04-09-2017 1:55 PM
@Gandalf - I appreciate that, thanks. And I'm thinking of buying a dual band router myself. Would the following TP-Link Archer AC750 be ok:
And will the 5ghz band work with laptops/tablet/phones from, say 2012? - Or are they too old to be compatible with that band?
04-09-2017 1:59 PM
From a quick scan of the specs and Google, it doesn't look like it's fibre compatible. I believe you'll need to find either a VDSL2+ router to use alongside your openreach modem, or a VDSL2+ modem router.
The good people on the community may be able to advise further.
04-09-2017 2:01 PM - edited 04-09-2017 2:02 PM
@Gandalf - It's mainly for an ADSL line. Fibre's not really available in my area.
04-09-2017 2:03 PM
04-09-2017 2:06 PM
Cheers. And re. old devices from 2012 (like a phone, laptop, or tablet), would they connect to the 5ghz band quite easily?
04-09-2017 2:15 PM
If you want a router with an integrated modem, Then look at these,
http://www.tp-link.com/en/products/list-15.html
04-09-2017 2:16 PM - edited 04-09-2017 2:18 PM
@DaveyH - Thanks. But I'm just looking for a standard but efficient dual band router for an ADSL line, rough price between £30-50 And not sure what you mean by xDSL. I'm not that techie-savvy I'm afraid.
