Connection, but no internet.
Paige1
All devices in the house are able to find the Wi-Fi, however once connected there is no internet or response… I have restarted, reset and turned on and off at the wall. Nothing has fixed since last night at 8pm?
6 REPLIES 6
Legend
Fixes: 260
Re: Connection, but no internet.
@Paige1 Are you on an  ADSL or FTTC connection? Which Hub do you have?
Paige1
I have ADSL connection.
How do I know which hub I have?
Legend
Fixes: 260
It will say on the bottom.
How technical are you?
Kandd18
Mine the same
Legend
Fixes: 260
@Kandd18 Same questions to you then.
As an aside, it is easier if you start your own topic - trying to sort two customers issues in one is extremely difficult.
adam945
Fixes: 113
Hey @Paige1
Thanks a lot for reaching out and I'm really sorry to hear that you're having issues with your broadband service. I've now been able to find the account through your Community profile, so please send me a PM with your account username and I'll be more than happy to help.
 Adam
 Plusnet Help Team - Leeds
