Confused about Premium Speeds
- Confused about Premium Speeds
- « Previous
- Next »
Re: Confused about Premium Speeds
22-12-2009 8:32 AM
Quote DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,067 / 19,563
Hooray, we got there at last, finally got ADSL2+ mode!.
That synch speed is about what you would expect from your line, it may drop a little during the next 10 days ( training period ) if the DLM decides to increase the noise margin. It just depends on what the error rates look like, but they are looking good so far
As Asbo says, your profile should increase pretty quickly, you can check your PlusNet profile at https://portal.plus.net/my.html?action=data_transfer_speed , if it hasn't gone up in a day or so then check your BT profile at the BT Speedtester and see if that's gone up. Your PlusNet profile should follow the BT one within 12 hours or so, if it doesn't then give CSC a ring or post back here and one of the Comms team should sort it.
I'm just happy we finally seem to have got your problem sorted, good work there Comms Team ( and Rami )!
22-12-2009 10:06 AM
Kudos to Rami for giving BT a kick.
22-12-2009 10:17 AM
First of all many thanks to everyone for your help on this, really appreciated.
BT Speed test reports this morning:
Download speed achieved during the test was - 10278 Kbps For your connection, the acceptable range of speeds is 1000-99999 Kbps.
Additional Information:
Your DSL Connection Rate :21730 Kbps(DOWN-STREAM), 1087 Kbps(UP-STREAM) IP Profile for your line is - 17000 Kbps
Plusnet profile reports this morning: Current line speed: 11000
The router reports this morning:
Uptime: 0 days, 1:20:55
Bandwidth (Up/Down) [kbps/kbps]: 1,087 / 21,731
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 5.5 / 12.5
SN Margin (Up/Down) [dB]: 9.5 / 3.5
Loss of Framing (Local/Remote): 123 / 0
Loss of Signal (Local/Remote): 11 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 15 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 20
HEC Errors (Up/Down): 0 / 16
So from what you are saying I should see that Plusnet line speed increase?
Still at last the download speed is faster so we are now feeling it was worth the wait:-)
Annette
22-12-2009 10:53 AM
22-12-2009 11:05 AM
Quote from: coastergrotto If the Plusnet profile doesn't rise to the BT profile today I would ring Plusnet Customer Support and ask them to reset it to match the BT profile.
No need, I've updated it to 17000 now.
22-12-2009 11:28 AM
Quote SN Margin (Up/Down) [dB]: 9.5 / 3.5
22-12-2009 3:50 PM
Annette
22-12-2009 5:05 PM
I just wondered if these are anything to worry about:
CRC Errors (Up/Down): 0 / 232
HEC Errors (Up/Down): 0 / 203
I think these were always at 0 previously and have gone up from 20 & 16 this morning.
Annette
22-12-2009 5:48 PM
Cyclic Redundancy Check and Header Error Control are generally higher in ADSL2+. The exchange is not reporting any HEC errors on both up and downstream you don't need to worry about this at all.
22-12-2009 5:52 PM
Quote CRC Errors (Up/Down): 0 / 232
Not really, a few hundred/day is not normally a problem. The DLM yesterday tried to see if your line could support a higher speed by dropping your target SNR to 3db and thus synching at 21,73. It might decide to put it back to 6db in light of the increased error count and your synch might drop back to the 19,563 ( or thereabouts ) but I dont think so, it needs something in excess of 1error/minute to do that and your 200 in approx 7 hours shouldnt be high enough to trigger it. Depends how it goes overnight though,as error rates do tend to increase at night.
- « Previous
- Next »
