Changed from BBYW upto 8Mb to Extra upto 20Mb but no speed change.
- Changed from BBYW upto 8Mb to Extra upto 20Mb but ...
23-11-2010 7:52 PM
Stable rate is unchanged at 6500
Router stats
--- System Information ---
Vendor: Linksys
ModelName: WAG160N
Firmware Version: A1.00.15 , 2009-05-31T16:58:02
GUI Version: A1.00.15_007
Boot Version: 1.0.37-5.4
Hardware Version: 0.01
--- DSL Information ---
DSL Driver Version: AnnexA version - A2pB022g.d20e
DSL VPI/VCI: 0/38
DSL Status: ShowtimeRetrain Reason: 0
DSL Mode: G.DMT
DSL Channel: INTR
DSL Upstream Rate: 448 Kbps
DSL Downstream Rate: 7616 Kbps
Down up
DSL Noise Margin: 8.4 dB 26.0 dB
DSL Attenuation: 32.0 dB 16.5 dB
DSL Transmit Power: 19.8 dBm 11.8 dBm
Also, how do I know if I'm on ADSL2+? My exchange is enabled and I'm just down the road from it, well within 1Km anyway.
Re: Changed from BBYW upto 8Mb to Extra upto 20Mb but no speed change.
23-11-2010 8:13 PM
ithe DSL connection for ADSL2 is something like G.992.5 annex A
I dont think your one is even ADSL
The PN staff can get you switched over possibly tomorrow
23-11-2010 8:15 PM
23-11-2010 8:22 PM
Fully complies to ANSI T1.413 issue 2, ITU-T G.992.1(G.dmt) and G. 992.2(G.lite) ADSL standard, so your line is G 992.1 which is the up to 8 M
23-11-2010 8:30 PM
Is there some switch that Plusnet have to flick to get me on the upto 20Mb product? They say I should be getting around 13Mb on that.
23-11-2010 8:50 PM
24-11-2010 10:55 AM
I've just gone the other way, from ADSL2+ to ADSL and it took 1 week for the change to implement for reference. I believe it was the 'Provisioning' team that sorted it for me.
Paul
24-11-2010 11:09 AM
Also you have to ask to be moved to ADSL2, it is not automatic. Have you raised a ticker to ask?
24-11-2010 12:18 PM
Quote SL Channel: INTR
Down up
24-11-2010 4:21 PM
Quote from: Peter Given the DS noise margin of 8.4 you are not going to see much of an increase going to ADSL2.
If that's the case, then why did your website tell me that I will receive an increase to about 13Mb from my usual 6Mb if I changed package?
My router stats today are:-
Vendor: Linksys
ModelName: WAG160N
DSL VPI/VCI: 0/38
DSL Status: ShowtimeRetrain Reason: 8000
DSL Mode: ADSL2+
DSL Channel: FAST
DSL Upstream Rate: 440 Kbps
DSL Downstream Rate: 9052 Kbps
Down up
DSL Noise Margin: 9.5 dB 29.6 dB
DSL Attenuation: 33.5 dB 16.7 dB
DSL Transmit Power: 0.0 dBm 12.9 dBm
24-11-2010 4:45 PM
Quote SL Driver Version: AnnexA version - A2pB022g.d20e
DSL VPI/VCI: 0/38
DSL Mode: ADSL2+
DSL Channel: FAST
24-11-2010 4:49 PM
I guess I'll give it a few days and see what happens.
24-11-2010 4:53 PM
Your ADSL2+ order was completed today so looks like pierre_pierre is right.
Jojo
24-11-2010 5:05 PM
24-11-2010 6:15 PM
