Changed from BBYW upto 8Mb to Extra upto 20Mb but no speed change.
- Re: Changed from BBYW upto 8Mb to Extra upto 20Mb ...
- « Previous
- 1
- 2
- Next »
Re: Changed from BBYW upto 8Mb to Extra upto 20Mb but no speed change.
24-11-2010 6:22 PM
24-11-2010 6:31 PM
I don't understand French but I think that's what he means
Jojo
p.s. yes, the 'soft reboot' tells the exchange that it was an intentional drop and doesn't affect the DLM
24-11-2010 6:57 PM
Je ne comprends pas le français mais je pense que c'est ce qu'il veut dire
24-11-2010 7:00 PM
24-11-2010 7:03 PM
Google is your friend
24-11-2010 7:06 PM
25-11-2010 10:11 AM
I think you mean ADSL2+ (ITU G.992.5). ADSL2 (ITU G.992.3/4) works in the same frequency range as ADSL. Atleast where Annex A is concerned.
Quote from: Peter Given the DS noise margin of 8.4 you are not going to see much of an increase going to ADSL2. If you are unlucky, you may actually see a decrease if the line is bad due to ADSL2 using additional frequency ranges which are more affected by a bad line than ADSL is.
Paul
25-11-2010 10:16 AM
Quote from: Forum Forum Language
The official language to be used with all postings on these forums is English
25-11-2010 1:53 PM
25-11-2010 2:02 PM
25-11-2010 2:10 PM
25-11-2010 2:12 PM
.........My aim was good, but still I missed
26-11-2010 3:45 PM
--- System Information ---
Vendor: Linksys
ModelName: WAG160N
Firmware Version: A1.00.15 , 2009-05-31T16:58:02
GUI Version: A1.00.15_007
Boot Version: 1.0.37-5.4
Hardware Version: 0.01
--- DSL Information ---
DSL Driver Version: AnnexA version - A2pB022g.d20e
DSL VPI/VCI: 0/38
DSL Status: ShowtimeRetrain Reason: 8000
DSL Mode: ADSL2+
DSL Channel: FAST
DSL Upstream Rate: 444 Kbps
DSL Downstream Rate: 11969 Kbps
Down up
DSL Noise Margin: 3.8 dB 29.2 dB
DSL Attenuation: 33.5 dB 16.6 dB
DSL Transmit Power: 0.0 dBm 12.7 dBm
It's just the 'Current Line Speed' that's going the wrong way. It was 6500, then jumped to 7150 and is now back at 6500 again.
26-11-2010 4:42 PM
Good sync rate. If that stays like that you'll soon have a profile of 10000.
Jojo
26-11-2010 4:57 PM
Quote It's just the 'Current Line Speed' that's going the wrong way. It was 6500, then jumped to 7150 and is now back at 6500 again.
can you quantify that?, is it from the BT Test?,, mine gives stupid impossible values, but the Mybroadband test is OK, Bob P agreed with me but never gave a reason
- « Previous
- 1
- 2
- Next »
