Can I have a speed reset please
- Can I have a speed reset please
Re: Can I have a speed reset please
26-10-2020 3:34 PM
@steve_arnold Keep your ears (and eyes) on this. Your test calls could have temporarily cleared the noise, but without a proper investigation, we will not know if the problem has really been fixed.
09-11-2020 5:07 PM
Apologies for not posting a update sooner, I raised a ticket and the reply said they had changed some settings but nothing changed, for the last 10 days I hadn't checked as busy looking after my nan.
To my surprise just checked the router and with a uptime or 36hrs it's reporting this - unsure when I reset the stats.
09-11-2020 5:20 PM
That looks much better, @steve_arnold , apart from the D/S SNR, but as mine has been running for over 60 days with a similar value, you may be on the way to a resolution. I'd just keep my eyes on it, and don't reset the stats - that can lead us up the wrong path.
11-11-2020 12:02 PM
Hi again,
Had a resync 2hours ago, I didn't reset the stats but they appear to have gone strange:
11-11-2020 12:10 PM
Steve, that looks better. Why do you think they've gone strange? - the ones I an make sense of seem to have improved.
11-11-2020 3:01 PM
Looks strange to me as upstream HEC errors, bit errors, total ES, total SES and total UAS along with downstream total UAS have gone down - surely they accumulate until reset?
Steve
11-11-2020 3:06 PM
@steve_arnold Sorry, hadn't really looked at those as the main indicators had improved. To be honest, can't remember if you said which modem/router you were using, but the overload of data on there is a little OTT for a home user. Maybe the data is reset on a re-sync?
11-11-2020 3:07 PM
@steve_arnold Upstream errors are reported by the DSLAM in the fibre cab so that has probably been reset or restarted recently so the error counts would restart from zero.
11-11-2020 3:10 PM
@RealAleMadrid He's on ADSL, 😁
11-11-2020 3:14 PM
OK same difference, the DSLAM in the exchange.😛
19-11-2020 4:44 PM
Hi again,
Only 1 further disconnect a week ago due to a power loss affecting our block of houses, the noise on the line has gone but this morning answered a call from a friend who lives about a mile away and immediately the connection dropped, it's remained connected for all other calls. As they call at the same time every week if the disconnects keep happening at the same time would that mean it could be a fault on their line.
One other thing is my attainable rate is showing as less than my actual rate since the power cut.
Steve
19-11-2020 5:04 PM
@steve_arnold Do you get many incoming/outgoing calls - seems strange that one caller alone can drop the connection. If the same thing happens again, run a Quiet Line Test as soon as possible and check for noise. It could be a fault on their line, but only they will know if it affects others they call. Can you try calling them, and see if the same thing happens?
Actual/attainable rates sometimes seem mismatched, I have seen it on my old router (but not the current one).
Couple of other points (1) Does your router report connection times - how long it has been connected for? (2) Your errors look a bit high, but without a time-frame, that's a little difficult to interpret.
19-11-2020 8:00 PM - edited 19-11-2020 8:02 PM
Last resync was at 0901 today when we answered the phone, previous resync was at around 1115 last Thursday when the power cut out. Managed to telnet into the router does any of this make sense to anyone?
ADSL info --stats
adsl: ADSL driver and PHY status
Status: Showtime
Last Retrain Reason: 8000
Last initialization procedure status: 0
Max: Upstream rate = 1148 Kbps, Downstream rate = 7856 Kbps
Bearer: 0, Upstream rate = 1151 Kbps, Downstream rate = 8791 Kbps
Link Power State: L0
Mode: ADSL2+ Annex A
TPS-TC: ATM Mode(0x0)
Trellis: U:ON /D:ON
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 9.4 5.5
Attn(dB): 42.0 26.6
Pwr(dBm): 0.0 12.3
ADSL2 framing
Bearer 0
MSGc: 51 12
B: 156 35
M: 1 1
T: 2 4
R: 0 0
S: 0.5696 0.9931
L: 2205 290
😧 1 1
Counters
Bearer 0
SF: 2269929 184660
SFErr: 126 167
RS: 0 2387171
RSCorr: 0 0
RSUnCorr: 0 0
Bearer 0
HEC: 228 126
OCD: 2 0
LCD: 2 0
Total Cells: 764108292 99930082
Data Cells: 7436252 620109
Drop Cells: 0
Bit Errors: 9401 9619
ES: 4746 1361
SES: 425 15
UAS: 455 325
AS: 36856
Bearer 0
INP: 0.00 0.00
INPRein: 0.00 0.00
delay: 0 0
PER: 16.23 17.87
OR: 28.08 8.05
AgR: 8785.68 1155.48
Bitswap: 6631/6631 0/0
Total time = 10 days 2 hours 8 min 37 sec
FEC: 0 0
CRC: 27669 2678
ES: 4746 1361
SES: 425 15
UAS: 455 325
LOS: 32 0
LOF: 45 0
LOM: 19 0
Retr: 5
Latest 15 minutes time = 8 min 37 sec
FEC: 0 0
CRC: 0 0
ES: 0 0
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Previous 15 minutes time = 15 min 0 sec
FEC: 0 0
CRC: 3 2
ES: 3 2
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: N/A
Latest 1 day time = 2 hours 8 min 37 sec
FEC: 0 0
CRC: 20 8
ES: 20 7
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
Previous 1 day time = 24 hours 0 sec
FEC: 0 0
CRC: 3085 220
ES: 450 139
SES: 55 0
UAS: 61 51
LOS: 1 0
LOF: 9 0
LOM: 10 0
Retr: 1
Since Link time = 10 hours 14 min 15 sec
FEC: 0 0
CRC: 126 167
ES: 118 108
SES: 0 0
UAS: 0 0
LOS: 0 0
LOF: 0 0
LOM: 0 0
Retr: 0
NTR: mipsCntAtNtr=0 ncoCntAtNtr=0
19-11-2020 8:13 PM
Not a great deal - to me.😉
But the times reported on there don't seem to tally - it says you've been up for 10 days, but you reported that it re-synced this morning. 😕
19-11-2020 8:36 PM
Summary page from router seems to show it didn't reboot with the power cut either although other electrical devices went off for around 10 seconds.
