CS Can you check to see if change over happened.
- CS Can you check to see if change over happened.
14-08-2010 2:41 AM
Regards Robin
Re: CS Can you check to see if change over happened.
14-08-2010 6:45 AM
I have checked your account and it seems your provisioned speed has not changed. This does usually happen when you change to the extra package. I have sent a ticket to our regrade team to have you changed to ADSL2+ and this normally takes about 24 hours.
Hope that helps,
Jojo
14-08-2010 9:39 AM
Thanks, fingers crossed for speed increase.
Kindest regards Robin
16-08-2010 10:34 AM
The ticket's been picked up and it looks like all should be working at the faster speed now, can you let us know if that's not the case please?
16-08-2010 3:42 PM
Just rebooted router still connecting via adsl max.
16-08-2010 3:48 PM
However, if you'd like us to regrade you then just let us know.
16-08-2010 4:09 PM
I changed package to try to get back to my old speed. Since 12 feb 2010 when exchange was up graded. I have connected at best half mb down from old connection speed.
After six months of trying to get speed back. I came to the conclusion plusnet are reducing speed deliberately. To blackmail all customers to new packages.
Reason last engineer changed paired in flat but told plusnet there was nothing wrong. I connected at the highest speed since 12 feb 2010.
Until plusnet checked my line now speed reduced again.
16-08-2010 4:42 PM
I have an old netgear 834pn router would it be worth trying with DGteam fireware.
16-08-2010 5:25 PM
If however things improve with the DGTeam then let us know - or if you'd like to go ahead anyway even though it may not mean an increase.
16-08-2010 7:01 PM
Netgear router connected
ADSL Link Downstream Upstream
Connection Speed 3424 kbps 448 kbps
Line Attenuation 63.5 db 31.5 db
Noise Margin 6.6 db 17.0 db
BT test
Download speed For your connection, the acceptable range of speeds Additional Information: Your DSL Connection Rate :3424 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM) IP Profile for your line is - 2742 Kbps The throughput of Best Efforts (BE) classes achieved during the test is - 22.04:28.65:49.31 (SBE:NBE:PBE) These figures represent the ratio while sententiously passing Sub BE, Normal BE and Priority BE marked traffic.
achieved during the test was - 1880 Kbps is 1000-7150 Kbps.
The results of this test will vary depending on the way your ISP has decided to use these traffic classes.
17-08-2010 11:10 AM
