Broadband issues again.
Lisacam381
How can I check if I have a fault on my line?...broadband drops out occasionally.
Does anyone know?
3 REPLIES 3
adamwalker
Fixes: 154
Re: Broadband issues again.
Hello there,
I've just looked into this, both your connection logs and the results of broadband diagnostics don't point towards any issues.
If you usually connect over WiFi can you try connecting to the router directly with a LAN cable to see if the connection still drops out?
 Adam Walker
Lisacam381
Thanks Adam will try that.
adamwalker
Fixes: 154
No worries, do keep us posted!
 Adam Walker
