Broadband constantly dropping out / orange flashing light
scoopadascoops
My broadband is constantly dropping out. I have reset the router a number of times but this is not clearing the issue. This has been happening at least a few times a day for a week with the frequency of drop out getting worse. It’s now dropped out a number of times in the last hour. Please help as I need this to be fixed so I can work. Thanks
4 REPLIES 4
wakeman
Re: Broadband constantly dropping out / orange flashing light
@scoopadascoops
Have you followed the broadband troubleshooting guide?
https://www.plus.net/help/broadband/connection-troubleshooting/
Once you have followed that is could well be you have a fault on your line, and thus need reporting.
scoopadascoops
Thanks @wakeman. Yes I have. There is no obvious issue. Do you know how I report a fault?
wakeman
@scoopadascoops
You could try faults.plus.net  that the link the staff usually give although it seemed to be playing up yesterday. if necessary try different browsers if necessary.
Otherwise its a call sadly to PlusNet
Gel
Aspiring Champion
Fixes: 29
Also do a "quiet line" test, by dialling "17070"; if you have noise on phone,
it'll degrade your BB connection.
