Broadband Speed
- Re: Broadband Speed
- « Previous
- 1
- 2
- Next »
Re: Broadband Speed
12-09-2015 9:48 PM
Unfortunately, if the banding is removed, it's likely to get automatically banded again, if nothing has changed and whatever caused it to be banded the first time is still ongoing. I guess they'll be reluctant to removed the banding while the Indicative Line Quality remains Red.
Plusnet staff are usually more active on these forums than they've been for the last couple of days, at least during office hours.
Message 16 of 18
(596 Views)
Re: Broadband Speed
14-09-2015 11:47 AM
Boooooo, I have gone from 21Mb to 0.5Mb
Message 17 of 18
(596 Views)
Re: Broadband Speed
14-09-2015 1:16 PM
Finally got a response from the faults team, and it is apparently due to the wiring in my property. Only problem is, there is no extra wiring in my property, I have a BT master socket and NO extensions, so, go figure!
Maybe the socket has become faulty since switching over, or my wife has had a couple of phone extensions put in without me knowing, I will need to check when I get home
On the plus side, someone is at least looking into it which is novel.
Message 18 of 18
(596 Views)
- « Previous
- 1
- 2
- Next »
