BT whosale speed test
- Re: BT whosale speed test
17-06-2015 10:29 AM
Why does the second part of this never work
FAQ
Results Image not loaded
1. Best Effort Test:
Download Speed : 1.15 Mbps
Your speed test has completed and the results are shown above, however during the test an error occurred while trying to retrieve additional details regarding your service. As a result we are unable to determine if the speed you received during the test is acceptable for your service. Please re-run the test if you require this additional information.
FAQ
Message 1 of 5
(852 Views)
4 REPLIES 4
17-06-2015 10:40 AM
I wouldn't say 'never', but it is a BTw product after all so it's bound to be flaky!
(Just tried it and it currently works for me, although it sometimes hangs on sending results to server, or gives the error message you have posted.)
Message 2 of 5
(568 Views)
17-06-2015 11:03 AM
Never for me , and would like it to work
Message 3 of 5
(568 Views)
18-06-2015 11:42 AM
We've got a couple of other lines that are having similar issues so I've added your circuit ID on to the escalation we're pushing. When I get a response (they aren't particularly quick) I'll let you know.
Message 4 of 5
(568 Views)
18-06-2015 3:42 PM
Thanks for that it should work
Message 5 of 5
(568 Views)
