BT Speedtester down???
- BT Speedtester down???
09-07-2009 12:35 PM
I use BT's SpeedTester ocasionally but it appears to be giving problems lately...
I thought it was my Firefox settings as I've been configuring an AddOn to stop pop-ups which eBay appear to be trialling.
However it won't run under IE either.
(if this has been mentioned elsewhere my apologies...)
Re: BT Speedtester down???
10-07-2009 8:13 AM
10-07-2009 10:28 AM
Just checked again this morning (~10am) and it's still down - well at least I can't get the page to open.
I've tried using Firefox and IE.
In FF I get the black bar along the top of the page with the "PERFORMANCE TESTER Your details will be verified after clicking on GO button" message then - nothing. At the bottom left of screen it says "Applet tickerapplet2 started" Then nothing.
In IE it tries to load the page twice then I get an error message saying there was a problem with the page...
It's been like this for a few days...
Strange, it's often a trifle flaky but usually works eventually, but it's been down for a few days...
pnnewbie
15-07-2009 9:51 AM
BT SpeedTester STILL down!!!
Checked with both FF & IE - nothing...
Anyone else have this problem?
15-07-2009 10:19 AM
15-07-2009 10:40 AM
Using FF 3.5 here too.
Normally have a couple of add-ons running (WOT & NoScripts) but I disabled both and still no luck.
The strange thing is that it won't work in IE either (Version
15-07-2009 2:39 PM
The strange thing is that it won't work in IE either (Version Eight)
15-07-2009 5:12 PM
17-07-2009 9:33 AM
With FF (v 3.5) I get a white screen with a black bar occupying about a fifth of the top of the screen, with the writing:-
PERFORMANCE TESTER
Your details will verified after clicking on GO button.
AT bottom left of screen, in tray, I have:-
I normally run a couple of Add Ons with FF but I have these disabled at the moment.
Using IE (the latest version) I just get a blank screen with 'done' bottom left.
'Must' be a browser config issue but I can't for the life of me see what it is!
17-07-2009 12:18 PM
the next is enter your phone number
the enter you user id - this is the same one that you put into yopu router i.e username@plus-----
this speed test require JAVA, have you got the latest version?
17-07-2009 1:50 PM
>did you click the GO button?<
There is no GO button displayed...
only a white screen with a black band near the top with the writing:-
PERFORMANCE TESTER
Oh and Java & Java script are enabled...
Someone tell me I'm doing something stupid - and tell me what it is pse!!!
17-07-2009 2:25 PM
Hiya,
Quote from: PNnewbie Above should have read:-
i have used this with I.E 8 and it works just fine although ive not tried it today,perhaps your page aint loading up correctly,also the weather up in scotland is lousy today,dont know if that is any use to you,does it say that its down when your at the page?
17-07-2009 9:00 PM
I've just run PingPlotter and it checks the route between me and BT Speedtester...
The last hop is shown as 'Destination address unreachable'
Now why should that be?
17-07-2009 9:26 PM
18-07-2009 9:23 AM
Now where's the pencil - I'll have those hundred lines done by dinner time..
I must think before I post
I must think...
