Am I on adsl or adsl2+
FIXED- Subscribe to RSS Feed
- Am I on adsl or adsl2+
- « Previous
- 1
- 2
- Next »
Re: Am I on adsl or adsl2+
14-02-2018 7:37 PM
14-02-2018 7:43 PM
14-02-2018 8:30 PM
Forget about the ADSL1 vs. ADSL2+ issue. It won't make much difference anyway due to the distance from the exchange.
You can also disregard the "acceptable" result from the BT Speedtester. It doesn't matter for this kind of speed issue. If your line speed were 0.5 Mb/s, and you got a speedtest result of 0.45 Mb/s, it would still say that's acceptable. It changes the acceptable range depending on whatever line speed you are connected at.
The line speed is very poor for the attenuation though. You should compare it with the estimates and the minimum guaranteed speed Plusnet gave you when you joined. Otherwise you may need to check out the wiring for all you telephone sockets, make sure any other sockets are dead while you're plugged in to the test socket.
15-02-2018 10:10 AM
15-02-2018 2:02 PM
- « Previous
- 1
- 2
- Next »
