Am I connected to a non-existent gateway?
Tony_W
Gateway checker says:
You are currently connected to the "Telehouse North, Juniper 5" gateway. This gateway is sometimes known as thn-ag2.
The Packet Drop By Gateway graph page seems to have graphs for thn-ag1 and thn-ag3, but not thn-ag2,
Amazing as I seem to be able to surf OK (although a little slowly).
Am I missing something?
Tony
8 REPLIES 8
jelv
Fixes: 10
Re: Am I connected to a non-existent gateway?
Are you on 21CN/ADSL2+ ?
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Tony_W
No, just "MAX" - as far as I know...
Fixes: 1,484
Not had any emails to say you were moving to 21CN - but staying on Max? PN have been moving people across.
Tony_W
No - I have just searched all of my emails (9000+) since 1999 for 21CN and nothing came up.
Edit - Exchange checkers say:
21CN due : (PSTN) Phone No Required
21CN WBC (Broadband) Not available
WBC Rollout Status
BT have announced a ready for service date for this exchange. The estimated go live date is between 1st March 2010 and 31st March 2010.
Tony_W
OK let's put it another way...
How can I tell if I am on 21CN?
Tony
pierre_pierre
do a BT speed test and you get a line of funny letters at the bottom, not there on plain ADSl
Tony_W
Thanks pierre_pierre.
I can't do a speed test just now as a disk defrag is taking nearly all of my processing/disk time.
However, I have not noticed any funny letters in the past, Would I still get them if my exchange is not 21CN enabled - it only gets implemented in March (see previous post)?
Tony
edit: Test now done:
Test1 comprises of Best Effort Test:  -provides background information.
Download  Speed
4748 Kbps
0 Kbps 7150 Kbps
Max Achievable Speed
Download speedachieved during the test was - 4748 Kbps
Additional Information:
Your DSL Connection Rate :7232 Kbps(DOWN-STREAM), 448 Kbps(UP-STREAM)
IP Profile for your line is - 5500 Kbps
If you wish to discuss these results please contact your ISP.
If you are experiencing problems with specific applications, servers or websites please contact your ISP for assistance.
Your test has completed please close this window to exit the performance tester.
bobpullen
Fixes: 316
thn-ag2 was originally used for our Tiscali LLU customers (of which we no longer have any). More recently it's been used for one of our 21CN host links, and more recently than that we've started routing normal 20CN customers' traffic through it as well.
The reason it doesn't appear on the packet drop pages is because the packet drops on the 21CN network are monitored using a different graphing platform. There are also multiple interfaces depending on exactly what type of customer you are.
It's not outside of the realms of possibility to get the thn-ag2 graphing up and running but it is going to require a bit of work.
