ADSL2
- ADSL2
ADSL2
21-01-2012 9:48 AM
Last night I received an email saying I would be moving over to ADSL2 over the next 5 weeks. Can someone please check whether I am currently on ADSL or ADSL2.
If im currently on ADSL can I be moved over ASAP please. My current downsteam is 6432kbps so im not sure which im on,
Many Thanks
Re: ADSL2
23-01-2012 8:55 AM
Re: ADSL2
23-01-2012 11:53 AM
You are currently on 20CN. Your order is due to to complete on the 7th Feb, so not too long to wait now.
Jojo
Re: ADSL2
23-01-2012 12:48 PM
Excellent news, thanks Joanne for the update!
Re: ADSL2
13-02-2012 4:48 PM
Am i right in thinking this is about the best im going to get then other than the upload improvement which seems to have doubled since the adsl?
ADSL Firmware Version
FwVer:3.11.2.175_TC3086 HwVer:T14.F7_6.0
Line State
Showtime
Modulation
ADSL2 PLUS
Annex Mode
ANNEX_A
Downstream Upstream
SNR Margin
7.6 5.5db
Line Attenuation
55.0 29.7db
Data Rate
5774 1107 kbps
POWER
0.0 12.3 dbm
CRC
34 0
Re: ADSL2
13-02-2012 4:55 PM
If you want more download speed you may be better using ADSL2, although your upload speed would go back to 448k.
Some modems allow you to choose, otherwise you may need to ask the PN staff
Re: ADSL2
13-02-2012 5:00 PM
Is speed the main difference between the two?
My attenuation has always been around this figure, over the weekend I was reading SNR margins around the 2-3 mark.
Re: ADSL2
13-02-2012 6:50 PM
ADSL2 is 12Mb Down and c0.5Mb Up.
Given your attenuation that max speed difference on download won't really matter. However the bits that are used for the extra upload speed on ADSL2+ will be used for extra download speed on ADSL2
Probably not 100% technically accurate - but hopefully you will understand.
If your router is set to auto it should choose the best option for you.....but may be worth switching to ADSL2 to see it improves your download speed any.
Re: ADSL2
14-02-2012 1:19 AM
Upload sync speeds on ADSL2 should be the same as on ADSL2+. I think the maximum is theoretically 1.3Mbps though just over 1.1Mbps seems to be the practical maximum.
Re: ADSL2
14-02-2012 8:42 AM
[Edit] Looking at this post it would appear that Plusnet do cap uploads, and Adam says uncapping can effect download speeds slightly:
http://community.plus.net/forum/index.php/topic,102222.0.html
