ADSL2 to ADSL with uncapped upload . Yes please
- ADSL2 to ADSL with uncapped upload . Yes please
28-06-2009 9:24 AM
Connection 4980kbps
Line attenuation 54.0 db
Noise margin 7.8 db
Thanks Martin
Re: ADSL2 to ADSL with uncapped upload . Yes please
28-06-2009 9:32 AM
Why do you need to do a reboot? Are you losing sync or PPP?
28-06-2009 9:35 AM
28-06-2009 9:39 AM
Martin
28-06-2009 10:11 AM
I have a similar but different problem with my DG834G - if the router is switched off at the mains and then restarted often the wireless connection fails. A soft reboot fixes it.
28-06-2009 10:21 AM
Martin
28-06-2009 10:25 AM
28-06-2009 10:29 AM
28-06-2009 9:05 PM
http://community.plus.net/forum/index.php/topic,77392.0.html
hope it helps
29-06-2009 7:20 AM
Martin
29-06-2009 10:47 AM
Have you tried uninstalling and reinstalling the wireless adaptor in your sons computer?
It sounds like a wireless issue rather than a problem with ADSL2+.
29-06-2009 11:03 AM
rebooting the router and unpluging an pluging back in the adapter has the same effect. so it defo points to your sons computer being at fault.
i had this problem last week around 3 times aday my comptuer would loss internet and the only thing that got it back was to reboot pc, unpluging the adapter didnt work in my case any way my adapter is right above the router but using wireless scanner i just nudged it a few cm's to get the best signal and havent had a problem since
30-06-2009 9:32 AM
jameseh and asbo dog. My son upgraded his P/C last week and reformated( Because he can) so he would have reinstalled the drivers after. I have changed the Channel on the router today ( thanks penfold) so am waiting to see if this makes a differance.
Martin
30-06-2009 9:35 AM
Please keep us posted
04-07-2009 10:25 AM
On looking at the wirless settings page on my router It connects by g&b( 802.11g & 802.11b wirless stations can be used). I noticed that there is also a setting Auto 108 mbps. As it is a 108 mbps router I changed to this setting and so far for 2 days now, we have not had to reboot the router. Keeping fingers crossed. Thanks for all who helped.
Martin
