ADSL problems re question #90453874
- ADSL problems re question #90453874
01-10-2014 10:42 AM
Hi
We've had two BT engineer visits to look at the disconnections/slow speeds and we're still having problems with disconnections and 0.3 mbps speed on our ADSL line.
Work done: new router, new BT faceplate filter, wiring replaced from faceplate to outside box.
Can the ticket #90453874 be re-opened so I can book another engineer visit please?
Message 1 of 2
(443 Views)
1 REPLY 1
Re: ADSL problems re question #90453874
01-10-2014 12:15 PM
Hi Heathercottage,
I'm sorry but the question is closed and cannot be reopened. If you open a new fault and refer to question # 90453874 in the notes we can pick it back up!
<a href="https://portal.plus.net/apps/kbdfaults"<u>Raise a fault here</u></a>
regards
Twills.
regards
Twills.
Message 2 of 2
(282 Views)
