ADSL guaranteed speed
- Re: ADSL guaranteed speed
01-06-2021 7:52 AM
My broadband had been consistently below the minimum guaranteed speed of 54.4Mbps, with a peak at just above 48Mbps.
I've raise a speed fault and was asked to provide 3 available engineer slots - the ticket then shows;
"Dear Mr Winter,
Rejected clear to eco.
Kind regards,
*name*"
Can anyone clarify what this message means, I'm assuming an engineer appointment has been rejected?
And what can I do to get (at least) my minimum speed!
"Dear Mr Winter,
Kind regards,
*name*"
Labels:
Message 1 of 2
(511 Views)
1 REPLY 1
01-06-2021 8:33 AM
@Mjw95 Welcome to the forums.
I can't explain the rejection message - suggest you ring Plusnet.
This is not an ADSL question - it is clearly Fibre. I have asked that it be moved to the correct board.
Message 2 of 2
(498 Views)
